chrisdvorak
Gold Member
I have a JD 410C backhoe that seems to have a fuel flow problem. I tried to start it and even though it was cold it seemed to take longer than usual to start, when it finally started it idled around 1,000 RPM and ran fine but it would not throttle up (even at full throttle it stayed at idle) I then shut the machine off and checked the throttle linkages and found no problems. I came back to the machine a few days later and started it again it was running on all cylinders but was surging between 500-600 RPMs then it stalled (start it again and it would do the same- then stall in a few seconds) My question is how would I tell if the lift pump was bad or if the injection pump was the problem? the lift pumps looks like it has been replaced recently but I have not replaced it so I don't know for sure. also the fuel filter has been changed
