Am I missing something
/ Am I missing something #1
Hammer Head
Lock Haven, PA
Kubota L3800 HST, Scag Tiger Cat
I was moving snow for the first time with my LA524 loader, I was not able to get the bucket to go into float position. Our older Kubota was down and lock for float.
Am I missing something??
/ Am I missing something #2
I was moving snow for the first time with my LA524 loader, I was not able to get the bucket to go into float position. Our older Kubota was down and lock for float. Am I missing something??
My BX25 is up and lock, don't know if that helps....
Sent from my iPad using TractorByNet
/ Am I missing something #3
the 2620 is down to the indent for float. My FEL control valve had to be replaced at about 50 hrs as it was defective and couldn't get into float. Dealer said they have had problems with valves. Hopefully your just has dirt in it.
I will have to try up to see if there is a detent. There should not be any dirt in the valves, only 2.5Hrs 0n the tractor.
I need to get it out of the garage and try all positions to see if I can find it.
Thanks
/ Am I missing something #5
I had problem with float detent on my loader when I first got it. Dealer came out and replaced some part (I wasn't home). I'm guessing it was a rust or corrosion issue- the tractor sat out on dealer's lot for about a year before I bought it. Some of these loader valves require a hole drilled to drain moisture that collects and causes rust, if you search old threads you'll find pictures and description.
/ Am I missing something #7
Don't know if this will help. On my B3030, they recommend that you turn your front wheels back and forth with the engine running for some kind of hydraulic glitch. Maybe you should try this.
/ Am I missing something #8
Put bucket on the ground and quickly(almost violently) push forward till you hit detent.
It was shocking how hard and fast I had to push the first time to get my front blower to float position.
/ Am I missing something #9
I don't have to do mine that hard. Just a firm push.
Thanks for all the help I will try all of the above, one of them should work. Some of these glitch solutions, push violently, turn the wheels back and forth, make it look like some of Kubota's engineers have been and are asleep at the wheel.
Tough to get a recall on a tractor!!
/ Am I missing something #11
It is not so much a violent hard push as it is a violent rapid push. forward/up on your control. Don't tear off the joystick, just "snap" it forward past the detent.
James K0UA
/ Am I missing something #12
^ What he said..^You go to slow you end up lookin up.
/ Am I missing something #13
I'd suggest you play with it with the engine off and bucket on the ground first, nothing will happen with the bucket but the valve will still go into float position. With yours you push the joystick firmly forward (as if to lower the loader arms). When you reach the end of the spring loaded travel, push a bit further and you'll feel the valve go past a detent and stop. That's float. Once you get a feel for it, start the engine and try it. Did you check the loader manual?
Sean
/ Am I missing something #14
"glitch solutions" "Turn the wheels back and forth" ...Recall"
What are you talking about? Nothing is wrong with the tractor. :confused:
Thanks all, it does take a hard push up to lock it in. Hope it will loosen up with use.
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
Wacker Neuson HI400 Heater (A61166)
Wacker Neuson...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
2007 KOMATSU GALEO WA200 LOADER (A62129)
2007 KOMATSU GALEO...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2019 GENIE S-80XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-80XC...
