Help, rough running engine in cold temps
/ Help, rough running engine in cold temps #41
3930dave
Thanks for the input on Simple Green. Just spray on and hose off. Generally I am doing this for the pragmatic issue of seeing problems before they manifest into much bigger ones like I have now and yes, I too have seen some pretty filthy machines working hard.
Though I don't want a parade queen, I do like the look of my new seat. My old one was getting pretty ratty after 8 years so I found a new one that just felt nice. I had to make it fit but it sure is purdy compared to the old duck taped one I had
No prob, anytime. On really built up grease you might need 2 rounds of SG treatment, but I like that it is pretty effective at moving grease, yet at the same time there is minimal skin exposure risk. I'll use a small nylon brush, or old toothbrush on stubborn spots.
Snazzy looking seat there - sure you ain't heading for a parade ? :cool2:
Rgds, D.
Nope, no parades, but the high seat and armrests just feel so much better when mowing a long stretch. My father recently purchased a new home with some acreage and bought the 1023r largely on account of my experience with the 2305. For his birthday, my sister and I bought him a new seat (original had a quite low back & no support). When I saw it mounted on his tractor I was thinking I needed to replace my own. Mine was starting to rust, tear and come loose from the metal back plate. The new one has a sturdy plastic backing that is molded into the padded front. The arms came as a separate kit. It took a bit of finagling to get into place, but it makes a huge difference in comfort and ergonomics.
SI2305
/ Help, rough running engine in cold temps #43
This is how it will look like once you have it clean and replace. I hope this will fix your problem. Sure won't hurt. :thumbsup:
/ Help, rough running engine in cold temps #44
I'm not singling anyone out in particular as to theoretical issues. I am however saying that air filter, fuel filter, fully charged battery and glow plug circuit functioning are the absolute basics of troubleshooting most any diesel engine. Condition of fuel going through the fuel system from tank to engine also. Anything else like the suggestion of an engine rebuild at 300 hours is preposterous in this situation. Just because a blue moon happened to one operator does not relate to this situation, and only serves to worry the OP for no reason.
To the OP: don't worry about the air filter cause and effect here, just change it because it needs to be done. Your engine isn't dirty, but it is dusty. Put on some latex gloves, grab hold of the fuel filter knurled locking ring and unscrew the housing. Catch the excess fuel, clean out the housing and replace the filter and reassemble it all.
Dusty conditions up the frequency by which items like air filters need to be changed on any piece of equipment, and can prevent overheating, poor fuel economy, reduce performance under load, etc.
Now get 'er done.:thumbsup:
I guarantee it will solve most if not all of your problem(s), unless some of the junk has bypassed your fuel filter and jammed up the injection pump, unlikely but a possibility nonetheless. We'll cross that bridge if it rises up.
/ Help, rough running engine in cold temps #45
Coyote machine, again I agree with everyone of your suggestion, but I just can't see where I have ever suggested an ENGINE REBUILT at 300hrs in anyone of my post. :confused3: Nuff said! Back to the OP. Lets wait and hope the fuel filter will do the trick.
/ Help, rough running engine in cold temps #46
You asked where, post #14, quoting you..."I hate to bring this up, but I had to replace my engine at 300hrs with symptoms that sound somewhat like yours. If you look into my older tread under ''2305 engine needs to be rebuilt'' you can maybe compare a few thinks but lets not get ahead of our self. "
Again, I said I was not singling anyone out, so just let it go....
/ Help, rough running engine in cold temps #47
SI2305
Not picking on parades..... a favourite rite of summer for me is the Canada Day parade that passes my place.... :thumbsup:
Nice seat, and I'm sure your Dad appreciates it too. As much as we all enjoy Seat Time, the armrests can be welcome on a long day, esp. with a sore back.
Rgds, D.
/ Help, rough running engine in cold temps #48
I think I see where the confusion is. I told him to look at one of my old thread that I had started in 2011. The title of the tread was (2305 engine needs to be rebuilt) I was referring to my engine 2 years ago. I did not say engines with a ''s'' meaning all 2305 engines. Sorry if my title brought some confusion. If you ever read the tread you will see where we came to the conclusion that it was just pure bad luck. Ok once again, let's focus on the OP.
3930dave,
Nothing wrong with parades, but definitely something wrong with an uncomfortable seat after several hours of seat time. Both my dad and I love them I especially always wanted a place to put my elbows. Bought it over ebay. I could dig up the old part number if anyone was interested.
SI2305
3930dave,
actually, part of this whole thread stems from the fact that I could not even see my filter in the first place. I do a regular maintenance routine, and I am getting close to getting some other issues that are approaching or overdue a bit (I need to change the engine oil, though by Hours I still have time left in it). As my tractor became more and more filthy, the less I could see the darkening sediment bowl. Right now, unfortunately is not the time to go spraying down the tractor, but it should be on my to-do list in spring. I really like your SG idea. I also don't like spraying a bunch of poison just to be rinsed off into my yard or water drainage.
SI2305
/ Help, rough running engine in cold temps #51
3930dave,
SI2305
The reason you can see it is the reason its darkening. The algae requires light to form and 350hrs over several years gives plently of stagnation in the filter so it can develop a foothold. What can be a good visual cue turns into a curse with infrequent use of the tractor unless its parked in the dark. The fuel system will perform best if kept opaque end to end.
I just did my first fuel filter change on the 7520 at 1250hrs. It looked pristime but I changed it anyway because I was experiencing lower power in winter until the tractor warmed well. Could be my warm up timing advance function that I already know has a problem.
larry
/ Help, rough running engine in cold temps #52
I'm not convinced that live diesel bugs necessarily require light, but I'm pretty convinced most strains need water to get rolling. Need a relevant micro-biologist in here to get a definitive answer.....
Back to the water - in Henri's picture I can see what looks like a red float ring at the bottom of the fuel sight bowl, that should indicate water level. What I don't see in any of these pictures is the water drain valve - could be the angle - is there a drain valve on the bottom of these bowls ?
Or is the drain valve somewhere else on these JDs ?
I might be repeating myself (been in a few of these type of threads lately), but it's worth it..... given the likelyhood of contamination, I'd be dosing the tank with a shot of biocide when doing the filter change/service.
Rgds, D.
/ Help, rough running engine in cold temps #53
Something to keep in mind..... water and microbial contamination may have little/nothing to do with your own fuel storage/handling practices.
IE. you wouldn't be the first to get contaminated diesel from a supplier.
Is the station you buy from a high-volume one ? Do you know anybody else who routinely buys diesel there ?
Rgds, D.
Found the culprit--my own stupidity and negligence!!
OK, I finally got to the dealer, bought both an air and fuel filter. I swapped out the air filter, started up and no difference. Then I went for the fuel filter. To say it was filthy beyond belief is but an understatement. The filter was solid encrusted black, a nice slug of water poured out of the filter bowl when I emptied it and to top it off there was a nice contingent of frosty ice actually attaching the filter to bottom of bowl! OK, I have learned my lesson about fuel filters. frankly I am amazed that the machine would run in normal temps given the filth of the filter. It makes my air filter look all nice and new! Pictures 1 and 3 are my old filter. Picture 2 is my Viking funeral I gave all the old fuel, paper towels, gunk and other gunk that I would otherwise have thrown away. Go ahead, let me have it!
/ Help, rough running engine in cold temps #55
Should have saved that filter; it looked fine to me. (Just kidding, of course.) Glad you got it sorted out.
PMH
Thanks!!
/ Help, rough running engine in cold temps #57
Congratulations, got 'er done :thumbsup:.
Larry has a good point, there was quite a bit of contamination on your filter, re. the # of hours.
With or w/o the red float ring indicator, keep a close eye on the water level from now on. There can be any # of ways that water is accruing - keeping track on the separator bowl will give you early warning.
Keep an extra filter on the shelf, and keep treating your fuel.
Rgds, D.
/ Help, rough running engine in cold temps #58
3930D. - thanks for advice to prime-fill new fuel filter in bowl to avoid contamination from pre-filling. I will be changing mine next year for 1st time, shoulda known better!
/ Help, rough running engine in cold temps #59
Welcome. Credit where it's due, that detail came my way from a long PM discussion I had with MHarryE.
A good general practice (no-prefill), but esp. critical on modern diesels. He detailed a design where Cat made a point of installing a final filter upside down, so it would be impossible to pre-fill.
In fact, that subject probably deserves a thread of its own.
How about it Harry ?
(Obviously, I don't mind posting :laughing:, but I'd sooner have the thread authored by MHE. I'd have to step up my knowledge on diesels just to catch up with what Harry has forgotten about them !).
Rgds, D.
/ Help, rough running engine in cold temps #60
Glad you got it solved. My concern is about what looked like rust on the caps of the filter, which could have gone past the filter into your injection pump and injectors. If it were my tractor I'd keep a very close eye on the new filter and the sight glass and if any further signs of water appear I'd drain my tractor fuel tank and again change the fuel filter. Treating your incoming fuel supply is one thing, existing possible contamination of your on tractor fuel tank is another. Consider yourself very lucky if you don't have any further damage down the line from the fuel filter as a result of that filter's condition.
New/Unused SD Lanch SDLGC100 6-Seater Electric Golf Cart (A61166)
New/Unused SD...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
New/Unused Quick Attach Hydraulic Rock Hammer (A61166)
New/Unused Quick...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
