First time in snow
/ First time in snow #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
Used my NH TC40D in the snow for the first time today; in the foothills outside Sacramento, we usually do not get more than a dusting now and then. Today, had 4-5".
Now I know what the north-east guys talk about; my R4 tires were not very impressive... Even with the rear tires loaded, traction was blehh.
/ First time in snow #2
It looks like by Wednesday or Thursday your snow should be gone. I don't feel one bit sorry for you. :laughing:
/ First time in snow #3
The the R4's are not great. I plow with them but have to watch the hills and off camber areas.
/ First time in snow #4
I've been plowing with R4's for 9 years and think they work great. I also use 4WD. They are terrible on hard pack snow or ice but so is any other style tire. That's when I add rear ballast and chains.
By the way, 4-5" here is what we call a dusting of snow. We usually don't get the tractor out for less than that.
/ First time in snow #6
That's the main reason I went back to titan R1,s.I hated my titan R4,s in mud and snow.Both sets of tires were loaded with rim guard.
/ First time in snow #7
In the same area, it's 24 degrees outside now and much of the snow is still there. Glad I don't have to drive around on what is probably ice at this point.
Ya, this is not the norm for us. Occasional dusting, but that is usually all.
/ First time in snow #9
Mine did pretty well today, but I have on heavy ballast on the 3pt as well as the loaded tires.
Another thing you can do is the cutting/siping thing with your R4s to add some more traction.
http://www.tractorbynet.com/forums/snow-removal/193438-cutting-groving-siping-r-4-a.html
James K0UA
/ First time in snow #10
Yeah, same here. Unless it's really wet, heavy snow I don't get the tractor out unless we get 6" or more. 3-6" I'll use the ATV to plow, under 3" don't even bother to clear it. I just let it pack down for a base.
/ First time in snow #11
James K0UA
Robert's best bet would be adding that ballast on the 3PH.
Frankly, filled tires don't do much for traction...definitely do add stability though. But, for best traction, get some weight on that 3PH!
As far as the suggestions about sipping...for a minimal snow area, MHO is it's not worth it...and definitely no chains.
/ First time in snow #12
I have read 100000000 posts on this chain thing . If you do not want to deal with them , then suffer . I don't care what tire you have , loaded or not ,ice is not intimidated by your big bad tires . If you want to handle snow it will take steel gouging it . Any sort of grade or offset doubles the problem . Think about your tractors weight , how much you are pushing just there . Let alone a blade / bucket full of snow . Tires engage dirt , pavement quite well . They do not get along with ice .
/ First time in snow #13
True dat. ^
I can't speak with any tractor experience because my Baby John is not allowed to play in the snow until I can budget for some chains. But trucks I know. The bigger (& heavier) they are, the harder they wreck. Don't screw around with ice.
/ First time in snow #14
I will use my chains tomorrow morning for the first time. Got 4 inches of snow this afternoon on my newly paved steep driveway. Freezing rain also forecast tonight on top of that so I'll push and sand first thing in the morning. Didn't really want to spend $550 for wheel spacers and chains, but now I feel better that I did.
/ First time in snow #15
Not sure what I am doing wrong(or correct...lol...)... but I run Titan R4's loaded with 3pt blower in winter and other 3pt items in summer. I only got stuck once in winter and that was due to the front tire getting stuck in a narrow ditch beside our lane while trying to plow/blow 12"-18" of snow with 24" to 30"+ drifts with a layer of ice to boot. I originally wanted agr tire but the dealer suggested I try the r4's. He said if there were issues he would replace them... never did. I often wonder about getting chains but they are pricey up here. Everything you guys in New England and south of that towards Virginia got over the last 24-30 hours we are getting tonight and tomorrow. Both the 2013/14 American and Canadian Almanac call for a mild winter with above average temps and precipitation. I looked back through my journals and almanacs and we had the same scenario 2 years ago. Snow, rain, cold and warm days which gave us lots of the ice. The ground would freeze and when the rain came it would freeze as it hit the ground = skating rinks for roads. I just hooked up the spreader today and loaded it with crusher dust. The guys at the pit said it would not freeze solid like sand - and it didn't... -8 Celsius last night and the crusher dust was wet from a previous rain. I broke through the crust of the pile and loaded the material into the spreader with a shovel. I also loaded a 24"x32"x48" plastic tote with the material when it was dry in the summer for winter use as well. I previously bought sand and it froze solid... lesson learned.
Tomorrow morning will either be a joy to wake up to or a pain in the butttt.... time to put more wood on the fire.
/ First time in snow #16
I must say chains work. I have a 2 wheel drive Kubota I mow with and put chains on it. Now it will go most of the places a 4x4 goes without chains. It is simply amazing!
/ First time in snow #17
I have chains...had 'em for years. But I'm in Vermont and previously lived in an area (south central PA) that would get a major Nor'Easter every few years.
Robert is just outside of Sacramento, CA in an area that, in his words:
...we usually do not get more than a dusting now and then. Today, had 4-5".
I wouldn't suggest the expense of chains in his circumstances.
/ First time in snow #18
Exactly. It is likely a once in 10 years event for his location.
I don't think Robert was asking for advice about chains, or anything else, just commenting on R4 traction.
/ First time in snow #19
That's correct...but I think others were responding to my post #11 in which I wrote:
"...for a minimal snow area, MHO is it's not worth it...and definitely no chains"
Ya, last good snow was 4-5 years ago. But my tractor was 30 miles away at my parents house. That was my old, smaller 19hp Kubota. I figured this TC40D at about 5000lbs with loader, filled tires etc would get better grip.
I've spent a lot of time over the years in Jeeps and pickups 4-wheeling in the snow closer to Lake Tahoe, so know how to drive ok in it.
Kind scared to think what chains would cost for 17.5x24 R4's...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
