My rear tires have water in them but not the front,should I put water in the front also!
It's been discussed before, but doesn't widening the front help stabilize the tractor more ONLY IF you're in a situation where you've maxed out the pivot capacity of the front axle? Otherwise it doesn't do much?
That is correct. The stability of a tractor is primarily determined by the rear tires.
Wider fronts will spread the contact patch on the ground and make dropping a front tire in a shallow hole less noticeable.
But as to keeping the tractor from tipping over sideways, by the time a rear tire lifts to the point the front axle oscillation has hit the stop you will already be heading toward disaster. Been there many times, not pretty, makes you drop your FEL load very quickly!!!
Spend your time and energy stabilizing the rear wheels and let the front do it's job of oscillation.
+1 You won't get ANY stability from a wider front wheel span until a rear wheel is already off the ground, when it's almost too late.
I understand what y'all are saying, but a wider front stance physically has to contribute to more stability. It may not be much, but the angle to tip number would be greater(inmho). Here is more food for thought, wider will also put more stress on the front axle and it's gear box.....I don't know if it's something to lose sleep over though.
It only contributes to more stability when the front axle has oscillated to the stopper.
Well, I have to disagree. So if you have two identical tractors, one set up like Bama with his wide stance, the other with tricycle gear on the front. On flat level ground I agree, same amount of force would be required to flip each, but the trike gear would flip sooner. Now, put them on an incline facing down at an angle and I would have to bet the trike gear flips first with less force. Just thinking out loud here, not trying to be a erk with a "J"![]()
