Looking for plans for loader
/ Looking for plans for loader #1
Hivoltage98
Member
Honey brook pa.
2008 cub 5254
I'm looking to build a loader for my cub cadet 5254 sub compact tractor. I'm on a budget like everyone else so I was looking to see if anyone had plans they could share so I could get an idea on material..
Thanks
/ Looking for plans for loader #3
one more hint, make a cardboard or hard board mock of things, use 1/4 bolts and washers for pivot points, and one can check movement of arms and bucket, on a full scale and see if thing will bind or not, make a life size flat cut out of the tractor, but once one has the cylinders one can see if the extension and closed positions what the paper drawing says it may be, try to keep the bucket as close to the front of the tractor as if extended, it puts more load on the front, and can lift the rear off easer,
/ Looking for plans for loader #4
Thanks
I recommend building some type of quick attach for it. I wish I would have done it when I put mine together: http://www.tractorbynet.com/forums/customization/272163-fel-toro-groundsmaster-put-together.html
Back then I didn't know that I would end up with so many attachments for it.
This brush fork is one that a use a lot.
The view from the seat.
Picked it up.
The burn pile.
Let us know what you come up with, since there are a lot of guys wanting to do the same thing. :thumbsup:
/ Looking for plans for loader #5
i would look at CAD Plans, they have a variety of different plans for various size loaders. I built one that fit a JD 400 tractor, the plans were easy to follow and the loader worked great.
2022 EZ-GO ELITE...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
White 6182 12R Planter (A66285)
White 6182 12R...
Landoll 18' Tilloll (A66285)
Landoll 18'...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
