Odometer
/ Odometer #1
ArtMech
Lithuania, EU
Present: 2003 Kubota M9000 DTF; 2001 Kubota B72. Sold: 1985 Kubota L2202
I'm planning to install auxiliary non-GPS odometer to my tractor. Have heard some types of them - Hub Odometer or Bike Odometer. But haven't heard anything about Tractor Odometer.
Does anyone of you guys use it? What kind, make, model? If there is any info on this subject please pass a link.
Main duty of that device will be to measure area while multiplying the mileage by mower width.
Thank you in advance.
/ Odometer #2
I would be concerned about measuring area by using a mower unless you are superman and can keep the exact same amount of overlap each path and figure out how to calculate for the turns.
/ Odometer
I don't think you need to be a superman to keep up an overlap constant. It's a matter of experience, especially for those who mow much with both, either side mounted mower or rear mounted mower.
Yes, I was thinking about the turns. In case of any kind of odometer, it needs that the mileage should be measured by the rear RH side wheel i.e. the closest one to the centre of the turning radius. I'm guessing all of us are turning to the right side while mowing. And the sharper the turning angle, the lower the angular velocity of the RH side wheel. So the mileage measured by that wheel could be closed to real on the turns. I don't say it'll be exactly real. Only a few passes on the same lot will show you, how precisely will the mileage be measured. But I'm sure it'll be more precisely measured then by GPS device, especially on the hilly lots or in the mountains.
I'm contemplating on the Bike Odometer.
The following link is just for example: Waterproof Bicycle Bike Cycle Wireless LCD Digital Computer Speedometer Odometer | eBay
Look at the price! If it doesn't fit a tractor, you can simply throw it away... or give it to your kid.
I was talking to sales person about it. To install it you need to attach a sensor to the axle casing and to stick a wheel magnet to the rotating axle so to provide a gap of 5 mm (~1/5"). And it'll start measurement. Salesman only doubted, would the system work if the speed will be comparatively low (I mean mowing speed). He said he's sure, no problem if that speed exceeds 5 km/h (~3 m/h) - it's nearly the walking speed of a human, if less - who knows.
Another one I was thinking about is a Hub Odometer (Hubometer).
Link here: http://www.mytractorforum.com/showthread.php?t=219889
What I don't like with it is, that it could be simply broken by the shooting out stones from the side mower discs.
Still searching for the best solution and good ideas on this subject.
/ Odometer #4
I really gps is your best bet really. Most any gps will have a tracking feature telling you how far you have travelled... and they are pretty cheap now- you could even use a smart phone if you have one.
/ Odometer #5
I have used milermeter.com for measuring fence lines. It would be easy to go around the field on their Website and find the area.
Here are some more options: https://www.google.com/search?q=mea...7&sourceid=chrome&espv=210&es_sm=122&ie=UTF-8
/ Odometer
Well I have nothing against GPS while using it on a flat terrain. But it gives some inaccuracy as I said on the hills which are dominating in the area I'm mowing.
Once I've measured my own lot area with a GPS three times while walking on foot. And each time the result was different. Even the contours gotten were not equal to each other.
That's why I'm thinking the method of surface copying by tractor wheel could give more accurate distance measurement.
/ Odometer #7
Maybe this is not practical but could you just walk the areas you work just once with a wheel?
Or could you use your county GIS if they have one? Or google earth?
/ Odometer
All you guys are offering is correct. Thanks for links. We have local distance and lot area measurement site too: Maps.lt.
Just from another angle. This is an example.
I have 2 customers for mowing. Both have the same lot areas, lets say 25 ac each. The 1st one's lot is flat, the 2nd one's is hilly. Mowing speed in both cases is the same, gear engaged the same. The hilliness of the 2nd customer is such, that sometimes I'm losing steering control climbing up a hill. The flat lot I'm mowing 7 hours, the hilly one - 8 hours.
I wonder, where am I losing 1 hour?
/ Odometer #9
Sounds like the hills on the hilly lot are causing you to spin a bit, which means you're moving slower. In other words, your "speed over the ground" is less on the hilly lot.
/ Odometer #10
Trigonometry is not my long suit, but aren't you traveling further on the hilly area? Suppose you have an equilateral triangle with a base of 100 yards with the end points labeled A & B and the apex labeled C. If you are on flat ground you would travel 100 yards going from A to B, but on hilly ground you have to go from A to C to B, a total of 200 yards. Does this make sense?
Steve
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
