Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #581
The 1953 Ford Jubilee has a category 1 3-point hitch.
Thank you! What is the difference between the Cat 1 and Cat 2 ends? From the pictures it looks like one is cast and the other is not?
   / Pat's Easy Change System - Order Online! #582
hi guys I've got a 273 TYM & looking at getting a set of easy change, has anyone here got a set for theirs (273) & how have they found them?
cheers!!
   / Pat's Easy Change System - Order Online! #583
That is correct, you will need a longer top link. I wish they warned people of that better. I knew of it but I had extra top links around from old larger tractors so it wasn't an issue to me.
lol I was just thinking that after putting up my post, I have an old top link so will cut & weld in the extra needed,
   / Pat's Easy Change System - Order Online! #584
I have a 1999 JD 6410 (95 HP). What cagtegory of 3 pt hitch is on it?
   / Pat's Easy Change System - Order Online! #585
buffitz45 according to tractordata.com its a cat 11. also just ordered my pat's qh today. I did a lot of searching on the net and realize i might need a longer top link, no big deal. Oh and for those who look at my avatar, the rear blower is replaced with a front mount. I will update my pic soon, so i don't have to worry about my pto drive being too short.
   / Pat's Easy Change System - Order Online! #586
Thanks, that's a handy link! Not sure if I can order from Pat's since I am in Alberta.
Any comment on not telling people their top links may end up too short?
Not everybody needs to change their top link or PTO shaft. It depends on the tractor and the implement. But we have added a note about this to the product description.
Both the category 1 and 2 models are now cast. The cat 1 -> cat 2 and cat 2 -> cat 1 conversion models are still hand welded.
   / Pat's Easy Change System - Order Online! #590
I had a phone conversation and said it was for a Kubota L5740. What's puzzling is that the top link distance to my Cat 1 disc is over 37". I'm having a hard time finding a Cat 2 top link that will travel that far.
Any ideas?
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2008 Ford Explorer SUV (A56859)
2008 Ford Explorer...
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
