MX 5100 backhoe, any advice?
/ MX 5100 backhoe, any advice? #1
Steppenwolfe
Super Member
The Blue Ridge Mountains
Kubota MX5400, 1140 RTV
I have an MX 5100 and I'm considering adding a Kubota bh 92 backhoe to it. I would appreciate any imput from others on their experience, good or bad, before I drop $10 grand on this. Thanks.
/ MX 5100 backhoe, any advice? #2
Kcender had one on his L3240, he can probably give you an idea how good it was. I know he put over 600 hours on it in a couple of years, a lot of that with the hoe in use.
Sean
/ MX 5100 backhoe, any advice? #3
How much digging are you going to be doing? The MX5100 looks to have 9.2 GPM available for the backhoe which makes it adequate for maintenance digging. What I mean by maintenance digging is an occasional hole here and there, but not excavating for a basement as an example. I have both a newer 14 GPM backhoe on a tractor and an older 26 GPM backhoe on an old Case backhoe. The 26 GPM out digs the 14 GPM obviously, but attaching the backhoe when I need it is a world of difference. Needless to say, I use the 14 GPM tractor backhoe more because I can attach it in about 10 min, compared to half a day. Excavators are heads and shoulders above backhoes for seroious digging, but they tie up a lot of money and space if you are only maintenance digging.
/ MX 5100 backhoe, any advice? #4
I have a MX5100. I bought a woods 9000 backhoe used. It came off a Kubota L4400. The brackets didn't fit my tractor so I had to cut and add a little. But to make a long story short I bought it for $3,500 plus approximately 20 hours of my own time to fix the bracket. It works awesome, I can't express how well it works. I can install and remove it in approximately 10 minutes that includes removing and installing the 3 pt hitch. I hope this is what you wanted to hear.
/ MX 5100 backhoe, any advice? #5
To my way of thinking, any tractor mounted hoe is designed for maintenance digging, or the occasional stump or burial hole.. serious digging on a regular basis calls for a regular back-hoe or excavator.
I remember Kcender commenting once he'd have been further ahead to buy a good used backhoe considering the amount of work he did with the 3240. Bottom line, they're not meant for heavy use, they meaning the tractor/hoe combination. Any add-on hoe will toss a tractor around like a dog with a rat if it's used hard, especially in rocky ground.
I've been impressed with the Woods 'hoe offerings, if the day comes when I can justify buying one that'll probably be my choice.
My further 2 cents :}
Sean
/ MX 5100 backhoe, any advice? #6
Absolutely 100% correct.
/ MX 5100 backhoe, any advice? #7
I'm very happy with my BH92 so far, it doesn't dig the same as a full size backhoe but I didn't expect it to. Have about 50 hours of dig time on it, these are the only pictures I could find.
/ MX 5100 backhoe, any advice? #8
Perfect. As I mentioned, I have both a Case Backhoe and a tractor with backhoe attachment. I get more use out of the tractor with backhoe attachment than the backhoe. Principally because I do occasional digging. When I need it need to dig it does that fine, and mine digs 11' deep almost the same as the Case's 12'. But it might be 3 months between digs.
/ MX 5100 backhoe, any advice? #9
I'm not mad at mine, but I haven't used it much. Makes great ballast for the FEL too. LOL
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2009 Mack GU813 Roll off Truck, VIN # 1M2AX13C59M007359 (A61165)
2009 Mack GU813...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
2018 Ford AWD Explorer SUV (A61569)
2018 Ford AWD...
429872 (A61166)
429872 (A61166)
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
