backhoe dolly
   / backhoe dolly #1
rjmack
cariboo wagon rd
GC2410
i was surfing youtube last year and saw a good idea for a backhoe dolly out of wood. [ame=http://www.youtube.com/watch?v=dRNO35pwUkE]backhoe dolly - YouTube[/ame]
so I decided to build one out of scrap steel, and used 6" casters instead of 5".
it works okay, next one i will build an offset into the front of the frame to enable it to wheel in and out from under the backhoe without having to use the outriggers to lift the machine up. i'll probably go to a harder caster as well, either poly or steel instead of rubber... that hoe is fairly heavy so the soft material on the caster makes wheeling the dolly a bit more difficult than it could be.
Massey Ferguson GC2410 backhoe dolly - YouTube
   / backhoe dolly #2
Excellent information. This video will be a great help when I build one for myself. Thanks for posting.
   / backhoe dolly #4
Just finished a dolly for the BH77 on my B3350. Using a simple T shape with 3 casters requires the extra 4 X 4 "block" to raise the bucket end so the lower end of the boom has clearance over the dolly. Tubes are 3" X 1.5" .120 wall, so fairly heavy, but it's what I had laying around :c). Cups for holding lower pins are from 1.5" ID pipe. Dolly has clearance to wheel into place under backhoe with stabilizers up. Will take another picture later with the hoe on it.
bumper
   / backhoe dolly #5
Nice work! When you going into production??:laughing:
   / backhoe dolly #6
Thanks for the compliment.
Any decade now!
I started retiring in my early 50's, as Mondays were hectic at the office . . . so I took Mondays off. Tuesdays immediately got way too busy, so I took them off too . . . etc. This went on for a few years until I was down to 3 hours a week - - sign checks and say "Hi" to everyone, then go fly my planes or glider :c).
Late 60's now and haven't set foot at the "company" for years. Son and his wife run it. Still, I've never been busier, and have no idea why I never seem to quite catch up! But I *am* having fun when I don't dwell on what's happening in DC and to the country I love.
bumper
   / backhoe dolly #7
Anyone make one for a Kioti 2485?
   / backhoe dolly #8
Murph,
I'd think most any steel fabricator or someone handy with wood could do it.
While I prefer steel for this sort of project, I've seen quite serviceable dolly's made from wood. The important thing is to select casters with adequate load rating and wheel diameter, and to locate them under the support points or nearly so. That way there's not much stress or loading, other than vertical compression, to the frame itself.
If I were building another*, I'd move the two wheels at the front a little further apart, maybe a couple of inches each side to add more stability (on my rig I can't go a lot further and have the dolly fit in easily. It's probably stable enough as is, as the center of gravity on the hoe is fairly low - and I can push hard on the assembly in any direction without apparent instability. It's one of those more is better things I guess.
Another design consideration is height of the dolly, especially the front, heavy end, supports. It's nice to be able to roll it in place without having to lift the back of the tractor with the hoe stabilizer. Also, and depending on the hoe attach design, I made mine so it is just tall enough to engage the "guide flanges" on the frame mount to keep the dolly right where it want's to be when lining up to reattach the hoe to the tractor.
* I honestly cannot think of anything I've ever invented or made that I didn't almost immediately think of a "better way" right after I'd made the first one!
bumper
   / backhoe dolly #9
wow really nice! I made a wood one for my BH65, but very similar design. I was able to get the height to match with the tractor perfectly so there's no using the outriggers to raise or lower it, I just wheel it into plact, push up with the bucket and pop the pins in. Metal would be better, though the wood has held up well for over a year now.
I created a platform for the bucket on mine that was a couple inches wider than the bucket. That's wehre the force is applied when lifting it into place, that allowed me to also get 2 casters under it to handle the weight better and to let me move it around with more stability. For the casters i went with heavy duty rubber ones as I find they tend to roll over small bumps on smooth concrete VS hard plastic, which likes to slide if you hit anything.
This is a link to the one I did out of wood, there's a few good designs on TBN for different tractors, but they all seem to look similar to the 't' type of style. http://www.tractorbynet.com/forums/kubota-owning-operating/236155-bh65-backhoe-dolly-build.html
   / backhoe dolly #10
tractchores,
I agree re. plastic wheels. The ones I used are here:
Albion 16 Series Industrial Medium Duty Caster - 6" x 2" Mold-On Rubber on Iron Wheel Swivel Caster - Amazon.com
BTW Albion used to be US made, but the forks and frame on these look suspiciously similar to something you'd find at Harbor Freight. Seem to be good quality though.
6", rubber on steel, 500 lb capacity. They seem to deal with the weight very well. IIRC, my BH77 is 850 lb, so there's plenty of reserve with only 3 wheels. One thing I've learned is not to take import wheels near their max load.
bumper
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
