Oil & Fuel Kubota MX5100 Engine Oil
/ Kubota MX5100 Engine Oil #1
loghill
Montrose, CO
Kubota
Does anyone have experience using Rotella T in a Kubota MX5100? The manual seems to say that you shouldn't use it because one of the many Rotella T specs is CJ4. The manual, if I'm understanding it correctly, says that CJ4 oil shouldn't be used because it's intended for DPF (Diesel Particulate Filter) engines. However, checking around with service people at various Kubota dealers, they all think it's okay to use. I can't get a Kubota Corporation service person to answer the phone so far to find out what they say and, if it shouldn't be used, what the risk is in using it. If anybody knows about using Rotella T in this particular engine, I'd appreciate hearing more.
/ Kubota MX5100 Engine Oil #2
It is fine to use it. Because your engine is not T4 you may want to shorten change interval but you will not hurt your engine. The oils are all backwards compatible.
/ Kubota MX5100 Engine Oil #3
Although many say it is fine it is a grade below the Kubota oil. Rotella is meant for over the road trucks which often are at low engine RPM's not continuous full or near full throttle use. Has a lower TBN number as well as sulfated ash is lower.
Is it okay to run it? As far as I'm concerned after the warrantee is off (so I don't have to worry about warrantee) you could put water in it and every repair shop will love you!
/ Kubota MX5100 Engine Oil #4
It is obvious that you aren't a fan of Shell products. Rotella T is just as good as any other oil of that class and advising a member that it will cause equipment breakdown it just plain wrong and saying that it is meant for over the road trucks needs some backup statement from Shell to go with your illogical rant. Why didn't you just go ahead and recommend your loved brand while at it.
/ Kubota MX5100 Engine Oil #5
I use Rotella T in four Diesel engines, including three kubota, with no problems. It is good oil
Thanks to those of you who gave serious answers to my question. I might continue to use Kubota oil, but my local dealer isn't carrying it anymore, the tractor is out of warranty and it's a long way to another dealer just to get oil. My concern was that this particular engine might be different than other Kubota engines and just wouldn't tolerate oil that included the CJ4 spec. I've used Rotella T in other, older diesel tractors and I know it's used in equipment by quite a few people, such as dirt contractors, etc.
/ Kubota MX5100 Engine Oil #7
You can use Rotella T with the same confidence as you have had with Kubota oil. All oils with that designation would be just fine and you will not damage your engine.
In an earlier post I mentioned T4 engines. I should have said Tier 4.
I have used Rotella t oil for over 20 years in everything from a gas auger engine to a 450+ hp tractor engine and truck engines. No problem. Many fleets use this oil.
/ Kubota MX5100 Engine Oil #8
Anyone have any experience with this?
/ Kubota MX5100 Engine Oil #10
I've been using Kubota oil, but Rotella is fine in Kubota engines.
/ Kubota MX5100 Engine Oil #11
What do you mean with the water comment???
/ Kubota MX5100 Engine Oil #13
I think too many people fret over brand. I am concerned about viscosity and operating ambients. 5w-40, 10w-30, 15w-40, make sure you have the correct viscosity 1st. Then, make sure you are using a HDEO that meets your engine specifications. This will be any API C_ oil on the shelves at your favorite store. Mobil, Valvoline, Shell, Delo, you really cannot go wrong with any of the top brands. Philip.
/ Kubota MX5100 Engine Oil #14
Does anyone have experience using Rotella T in a Kubota MX5100? The manual seems to say that you shouldn't use it because one of the many Rotella T specs is CJ4. The manual, if I'm understanding it correctly, says that CJ4 oil shouldn't be used because it's intended for DPF (Diesel Particulate Filter) engines..
I want to say one of the Kubota models had a mistake in its oil listing in the owner's manual. I am not positive of that.
/ Kubota MX5100 Engine Oil #15
/ Kubota MX5100 Engine Oil #16
I have used it in mine without any issues at all
/ Kubota MX5100 Engine Oil #17
Kubota brand oil is made by Ashland oil, the makers of Valvoline. I use Valvoline in all my gasoline engines except the ATV. The diesel engines and the ATV have all used Rotella synthetic since the first oil change. I started using Rotella dino oil in 1980 and transitioned to synthetic in the early 2000's and have never had an issue.
/ Kubota MX5100 Engine Oil #18
I've used the same Rotella 15w-40 for that many years in all our equipment - gas and diesel both. Never had any reason to think it was less than excellent. And we've never had a lube-based failure. However, I've no reason to believe that other oils aren't just as good.
rScotty
/ Kubota MX5100 Engine Oil #20
Gary if you follow oils Rimula from Shell does a far better job of matching the Tractor grade engine oils then Rotella does for TBN as well as sulfated ash both base lines needed for diesel engines that the tractor manufactures have put together for the longevity of their products. I do have oils that I prefer although as I stated I really do like to see what I sell live a long time and you can use what ever you want!
Will the average tractor user here have issues with his 500 hour ten year old tractor probably not! Five thousand hours and it becomes more of a probability. We have seen different oils that have stopped oil consumption or slowed it's use! We have seen different oils that have improved the fuel economy in farm tractors as well as commercial users of small engines.
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
2012 MACK GU GRANITE 6X4 T/A ROLLOFF TRUCK TRACTOR (A59914)
2012 MACK GU...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
