Posthole Digger Shear pin for Post Hole Digger
/ Shear pin for Post Hole Digger #1
stumpfield
Gold Member
Sierra Foothills
2005 MT265B
I got a Bush hog 2101 post hole digger. The manual calls for a Shear pin .375" x 2.5" Bush hog part # 83379. I called all the nearby dealers but none have any in stock. It must be special order and it could take 2 weeks. I really need to use the PHD this weekend. Is there an equivalent or other replacement for this particular shear pin? Will a regular grade 2 bolt work?Thanks.
/ Shear pin for Post Hole Digger #2
Look at the bolt head and see what grade the original is. If unmarked then a grade 2 is a good place to start.
/ Shear pin for Post Hole Digger #3
I bought that post hole digger. Or so I thought. But, I couldn't get the roll pin to stay in. It just kept coming out. It never did seem right. There was no way to keep it in. So I called the dealer. Had him send me a new roll pin. And while he was at it, I had him send me 4 of them.
Turned out, the dealer gave me the next model up (2102?) and didn't realize it. That's why the roll pin didn't fit right. He then told me that for mine (not yours), that it just uses a 3/8" soft bolt that could be purchased at any hardware store.
Here's the kicker: That roll pin was $9 for one! I about fell out when I got the $36 bill for the 4. Needless to say I sent them back. Glad the dealer made a mistake and gave me the "better" model with the cheap shear bolt.
So, after this story: Try Rick Wallace (Kioti dealer in PA). He probably has some pins he can send you over night.
/ Shear pin for Post Hole Digger #4
FWIW, the manual for my digger (it is NOT a Bush Hog), calls for a 3/8 x 2-1/2" grade 2 shear bolts. I buy them by the pound and keep a sack full on the tractor, I have lots of rocks :mad:
YMMV
Ken
/ Shear pin for Post Hole Digger #5
Sounds like you go through a lot of these. What do you think of putting a grade 5 bolt in?
/ Shear pin for Post Hole Digger #7
I would rather replace a dozen standard bolts than to have to replace the gears that they protect.
Follow the instructions in your manual. Some things are designed to use grade 5 bolts as shear pins, others are designed to use standard bolts to protect the rest of the device.
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2020 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER (A65056)
2020 CATERPILLAR...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
500 Gal Propane Tank (A64912)
500 Gal Propane...
PT 1100 Gal Supply Tank (A64911)
PT 1100 Gal Supply...
