12 volt defroster
/ 12 volt defroster #1
DABSGT
Connecticut
John Deere 2032r
I have a Curtis cab with heat on my JD855 but found the heater doesn't help keep the front window clear. Would any one have any recommendations for a defroster that they have seen or used?
Sent from my iPad using TractorByNet
/ 12 volt defroster #2
I don't have an answer, but since I also have a new to me JD with a Curtis cab and heater, I will be watching this thread. I was thinking a small fan in the cab directed at the windshield might help, but I hope others chime in from experience.
/ 12 volt defroster #4
I use a 12V ceramic heater in my cab. I have a glass windshield and fiberglass top roof but the rest of the cab is the soft vinyl w/ plastic windows. Haven't had a problem keeping the windshield clear. I usually wait till the storm is over and not snowing and blowing. The heater I have is made by RoadPro model RPSL681 and is only 300 watt, and draws about 22 amps. (KW's post shows it on Amazon for around $31. It is directly wired to the battery with a toggle switch due to the heavy wire I used. Just have to remember to turn it off when parking the tractor. I have it mounted at roof level behind my head on the right side blowing toward the windshield. I don't even have to wear gloves in the cab once its going. I think using one of these to supplement your heater would keep it clear.
/ 12 volt defroster #6
I have a curtis cab on a NH TC40DA with the heater. It has a 2 speed fan up high and to the right. It works fine to keep the condensation & frost off the windshield if I have the heater running on all but the below zero days. Then I have to scrape a bit inside. For my Electric Polaris Ranger, I have tried those cigarette lighter plug in heaters without much success and they draw a lot of amps. That ceramic direct wire heater looks good.
/ 12 volt defroster #7
Moving air will help defrost a window, naturally heat helps a lot.
I use a computer type 12 volt muffin fan and simply blow air at my rear window.
I mounted it on a magnet so that I can position for best effect. Works fine for me and I can now breathe while looking out my back window.
/ 12 volt defroster #8
I had the same problem in my bobcat 2100. It also has a Curtis cab. The heater I used was from Harbor Freight. It was not the best but it worked and it was cheap.
12 Volt Auto Heater / Defroster with Light
/ 12 volt defroster #9
I'd think that a muffin type computer fan would be a good choice - lots of air flow and low current draw.
/ 12 volt defroster #10
I too have a Curtis cab and the fan idea is the way to go,, The Curtis heater is great,, I'm in a tee shirt and 0 deg...
/ 12 volt defroster #11
You can buy 12 volt fans to circulate the air and keep the windshield defrosted. They even oscillate side to side. Cheap ones are around $25/30 at the auto parts store but the all metal ones like in buses will probably last longer.
TEREX RL4 LIGHT PLANT (A60736)
TEREX RL4 LIGHT...
2020 MACK GRANITE QUIT AXLE DUMP TRUCK (A59906)
2020 MACK GRANITE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2016 FREIGHTLINER CASCADIA (A60736)
2016 FREIGHTLINER...
(INOP) 1991 GMC DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
