Busted pivot rod on 400cx loader?
/ Busted pivot rod on 400cx loader? #1
tinsnip
Maine
2006 JD 4120
OK, not sure what the real name of this part is, so I'm calling it a "pivot rod". The part in question is a silver-colored rod that spans the width of the loader and goes through the joint of the loader "feet" from one side to the other (see attached photo). While switching from the bucket to the pallete forks yesterday, I noticed the left "foot" was acting weird and appeared to be moving sideways when pushed into the all-the-way-down position. On closer inspection, it appears as if the rod in question is sheared off just to the inside of the foot.
So am I correct in assuming that the rod/part is a continuous piece that runs all the way through both arms/feet and if so, how big a job is it to remove and replace?
Thanks!
Tim
/ Busted pivot rod on 400cx loader? #2
It's called a "timing rod", and I don't think its difficult to replace. There are a couple 1/4...maybe 5/16 pins that need to be driven out. I don't know if you have to take one of the feet off, or not. But if you do, the large pins come out easily.
/ Busted pivot rod on 400cx loader? #3
I have a 4520 and purchased mine for clean up after a tornado crossed property laying down 30 acres of trees. so have used the FEL. for a lot of lifting of logs and the twist has broken this bar several times. Used to purchase from J.D. a new rod and they charge like it is made of gold. then welded the broken parts together and reused .
Look carefully at the cross member of the FWL the weld on mine was not holding the arm and was shifting when load was on one side. removed from tractor and rewelded the cross member and quit breaking the rod.
ken
/ Busted pivot rod on 400cx loader? #4
That rod is called a timing rod. It keeps the left and right attachment feet in sync. I had to replace the one on my 400X loader last year. It's not a difficult/big job at all. It is one continuous rod with grease zerks on each end and runs all the way through both left and right side. I used a wooden dowel and a hammer to drive out the old rod. IIRC, it was around $120.
Thanks gents! Exactly what I hoped (except for the $120 part). Will order the part and check the cross member to be sure it's holding. To be honest, I don't even know how long the situation has existed but over the past several years I've lifted a ton of big stuff (like 28 ft. pine and massive boulders) so it's not a surprise that a twisting motion would make this happen. The break must be inside the foot since from the outside it still looks whole.
Thanks again!
Tim
/ Busted pivot rod on 400cx loader? #6
Are you sure that you didn't just shear the pin? Look at item 20.
  • Loader 400cx.pdf
/ Busted pivot rod on 400cx loader? #7
Excellent point. This fix would be way cheaper and easier than replacing the bar. This has happened to others here on TBN so it does happen. In fact, these pins should shear before the bar breaks but it doesn't always work that way.
/ Busted pivot rod on 400cx loader? #8
Happened to me on a 200CX on a 2305. All it needed was a new pin.
/ Busted pivot rod on 400cx loader? #9
Same here on my JD 640 loader, sheared or lost a pin, easy fix.
Just received the replacement timing rod via UPS today. I took the old rod out before ordering the replacement and sure enough, it was busted. It broke cleanly in the exact location of the hole that accepts the pin. Since that hole is covered by the flange of the loader's foot, it was completely invisible. I removed the bucket and lowered the feet onto blocks and without the weight of the bucket, I was able to grab the short, broken end and pull it out without any difficulty. The other side was a different story since I think it might have taken a bit of torque. But it's all out now and the new one goes in tomorrow.
Thanks again for the help.
/ Busted pivot rod on 400cx loader? #11
Yep. Very similar to my experience. What did they soak you for the timing bar?
/ Busted pivot rod on 400cx loader? #12
**2022 UPDATE for anybody having this problem** I have a 2019 1025R and my timing bar sheered off at the hole for the pin location. The price now is up to $225.00. I haven't tried to "knock out" the old rod yet, I hope it isn't too hard to do without messing up the zerks. Looking ar the new part, I really don't see why there are zerks anyway.
/ Busted pivot rod on 400cx loader? #13
tj
What is the part # ?
What is model # of the FEL?
/ Busted pivot rod on 400cx loader? #14
This is soooo funny. I think that one of the pins for this rod has been sheared for many years on my 4600. It's only a problem when I have to change the bucket to the forks. When I change the angle of the mount feet, one side will typically move faster. I never understood that this is a torsional rod to keep the two sides in sync. Duh!!!!!!!!!!!
It really pays to read through these threads!!!! I'm always learning something new!!!!!
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
IRET13 Electric Tricycle (A64047)
IRET13 Electric...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A63569)
1994 SHOP MADE...
