Baling corn stalks
   / Baling corn stalks #12
Newbe here, Can corn stalks be sold as biomass material to a local processor?
They can as long as you have a processor close by. I would call and ask before baling any. Removing corn stalks from a field(baling or grazing) greatly increases the P&K removal of the crop so make sure you are replacing the removed nutrients.
Vermeer's manual has some adjustments to make to baler. One is the throat clearance and the other is to run PTO at 75% of rated. There maybe some other so check with the manual.
   / Baling corn stalks #13
It you think corn stalks is bad, try baling peanut hay.
None of us northerners are familiar with peanut hay. I would like to hear about it.
   / Baling corn stalks #15
Peanuts are grown in very sandy(sugar) soil. The vines are tough combined with the sand is very abrasive on a baler.
   / Baling corn stalks #16
Okay here goes. Using the slid rule for "nutrient removal", which is what we use when making fertilizer recomendations, removing the "stover" or stalks from 180 bushel per acre corn will remove 66lbs of N, 14lbs of P2O5, and 60lbs of K2O. Using Urea, DAP, and Muriate at current prices (and rounding a bit). To replace the N removed will cost $30 per acre, to replace P2O5 will cost $5 per acre, and the K2O will cost $22 per acre. Of cost if the corn yielded more the replacement cost will be more and vice verse. So basically you will need to add $55-60 per acre of fertilizer to bring you back to where you were AND THEN ADD the fertilizer needed for next years crop.
Add to that the cost of chopping, raking & baling. It makes me wonder if it's worth it. You will also be depleting the organic matter over a period of time. It's perfectly fine when it's used as bedding for your own livestock, and it ends up being spread back in your own field.
   / Baling corn stalks #18
As I'm sure you know, peanuts must be dug and flipped over to dry. The process for digging peanuts basically leaves the ground in a plowed state. After a few days in the sun, the peanuts are picked/combined and the hay is ready to bale. Just imagine running your baler through a 3 day old plowed field.
Sometimes you cannot see the baler behind the tractor, the PTO shaft just disappears into a cloud of dust. There no way to keep it totally out of the dirt, so you do end up running a lot of dirt through the baler. The hardest hit area is the pickup, but most of the newer belt balers handle it very well (you don't want to use an old chain baler). Peanut vines are tough and years ago we always square baled it, so you can imagine the amount of dirt on the knotters. It still did let damage to the baler than it did to you hauling it.
Peanuts "straw" makes excellent cow hay and I have often heard that it's close to alfalfa in its nutrient value, but I never really looked it up to confirm. I can tell you from personal experience that if you put a bale of your best coastal hay and a bale of peanut hay in same pasture, a cow will eat the peanut hay and lick the ground clean before even thinking about the coastal.
   / Baling corn stalks #19
Jim, I agree with you on the vines being tough and the dirt being abrasive, but in our part of the world very few peanuts are planted in sugar sandy soil. Maybe there’s a difference between our views on soil types, but in GA we have a lot clay.
From your picture, that was a nice size peanut field.
   / Baling corn stalks #20
I don't recall ever seeing peanuts grown in any other type soil other than sand here where I live. Back in the 60's - late 80's when I worked for a JD dealer a lot of acres of peanuts were grown but not very much now. I agree on the excellent quality of peanut hay. I remember sq peanut bale handlers wearing leather chaps to protect pants/legs from extreme abrasive stalks.
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
2014 Toyota Camry (A56859)
2014 Toyota Camry...
2018 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2018 Chevrolet...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
