home made cab
/ home made cab #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
anyone here with a factory cab,,,I would like to find the distance from the seat to the ceiling of the cab for headroom. I am in the process of building my cab for my new ck30 sold my mf 1020
thanks
/ home made cab #2
Sitting in the seat, add about 6" from the top of your head. (think my cab is about 3-4" clearance.)
Also be sure it clears your garage door opening (or shed).
/ home made cab #3
Clearing a garage or shed door is probably the most important factor, but there's more than 3-4" clearance over my head in my cab. I'd have to measure to know the height on the inside but I can tell you my CK30 with Kioti cab easily fit into my 95" garage door opening and my DK45 is about 1/2 too tall. If I had to guess on the CK30, I'd say I had about 4" to spare, making it around 90-91" tall but there is a ceiling and a roof in those cabs so it's a bit lower on the inside of the tractor.
/ home made cab
thanks fellows ,,, did some measuring today ,,total height under 80 inches so will go in garage if required
all ready for build ,,,still deciding on wood or metal framing ,, no welding experience ,that's why indecision
but thanks again for the input
total cost should be less that $700 so great for removable winter cab
/ home made cab #5
Do bolts or rivets then. Metal is better.
/ home made cab #6
This sounds like a great excuse to buy a welder and learn. A 180 amp might welder isn't terribly expensive and will serve you very well for all sorts of projects. YouTube has plenty of videos to get you welding like a pro in no time.
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2015 KENWORTH (INOPERABLE)T800 (A65643)
2015 KENWORTH...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
