PTO pump size for BX
/ PTO pump size for BX #1
twomorestrokes
Charlotte
Kubota BX2230
Been getting ready to hook my new Ramsplitter 3pt wood splitter up to my BX2230 using the tractor hydraulics. If I decide to go with a Prince PTO pump instead, how big of pump can that PTO run? Looking at 11 GPM vs 17 GPM. What are you guys using on your BX series tractors?
Mike
/ PTO pump size for BX #2
Per Surplus Center that 11.4 pump takes 18.1 HP. Your BX like mine has 17 HP at the PTO. Considering 20% losses that is the biggest you can safely go, but depends on how you load the cylinder using the fluid. Stick the ram and you could stall the engine. I would make sure to have a relief valve set before the stall pressure. I am considering the same set up so will be waiting other replies also.
Ron
Ron
Good information! Guess 17gpm is out. If I go this route I may try an 11. I'd bet it would be ok setting it up as you describe on anything but the most knotty wood.
/ PTO pump size for BX #4
How is it that my 22 ton pull-behind splitter with 6.75 hp can split the most narley wood, but a 17 hp pto won't drive any splitter without fear of stall?
Ryan
/ PTO pump size for BX #5
How is it that my 22 ton pull-behind splitter with 6.75 hp can split the most narley wood, but a 17 hp pto won't drive any splitter without fear of stall? Ryan
The dedicated splitter/6.75hp engine has a 2 stage pump. Hi speed/volume for quick ram movement Low speed/volume for tough spots in the wood. The pump will do this on its own when it senses increased pressure/reduced volume flow (exactly how I don't know) The pump that the OP is considering does not "downshift" like a 2 stage pump requiring much more hp. Hope this helps!
/ PTO pump size for BX #6
Ericher,
That begs the question...why wouldn't a two stage pump be offered for the pto as well?
/ PTO pump size for BX #7
Ericher, That begs the question...why wouldn't a two stage pump be offered for the pto as well?
I don't know
You may want to PM member J_J as he seems to be very knowledgeable in hydraulics!
/ PTO pump size for BX #8
I was going worst case scenario on my post. Depending on what you split you will probably never develop the full 11 HP load. I have a little 5 Ton electric splitter that is amazing. I am convinced that 35 Ton splitters are designed to get the money from our bigger is better notions. Based on what my 5 ton will do any more than 10 ton is probably more than any but professionals working 3' logs will ever need.
Ron
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A61165)
2008 Kawasaki...
1999 Sterling L7501 Dump Truck, VIN # 2FZHRLLB5XAA64093 (A61165)
1999 Sterling...
PC 4500 Pallet Jack (A61166)
PC 4500 Pallet...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
