Eucalyptus splitter.
/ Eucalyptus splitter. #1
simonsays
Member
Auburn, CA
MF 50EX, Gravely's
I have been splitting firewood pretty much since I could walk. I thought I had split everything..... including many different varieties of eucalyptus. I recently ran across some old growth Red Gum Euc that was next level! The hydro splitter that used to get me through splitting almost everything was brought to its knees. I have seen some awesome home built machines on here so I thought I would ask everyone's thoughts on the ultimate setup for the gnarliest of wood.
It seems that many of you are Midwest so I am not sure if eucalyptus grows there. It is definitly all over the west coast. I would not doubt that you have something similar. I'm sure Midwest has some of its own challenging wood. Some of the attributes of red gum are that it's SUPER heavy green and seasoned. Very hard but not extremely dense if that makes any sense. It's stringy when wet and shatters/cracks when dry under the knife. It can be very knotty and/or a twisted grain.
My design that I think would work best.
VERTICAL BEAM- due to whe weight of the biskets
5"x24" RAM- think that is capable of 37ton
18-22 HP ENGINE- surplus center sells a 22 hp vertical for $520, I thought that was reasonable
28 GPM PUMP-
I already bought a 6"x8" H beam. It's approx 9/16 thick.
As you can see I want to build a beast. You may be asking: "why do you want to split that crap?" It is very plentiful here in SoCal and it puts out impressive BTUs.
/ Eucalyptus splitter. #2
Welcome to TBN! Real nice first post.
Out here on the East side we have this thing called elm. Gnarly as the day is long. When I used to split with a sledge & wedges I had a wedge get spit out 4 or 5 ft in the air after being driven deeply into a round. I haven't had the chance to try splitting any with the new hydraulic splitter, but I look forward to trying some maybe this weekend.
Good luck with your build and I look forward to seeing what you come up with!
/ Eucalyptus splitter. #3
I have elm as the most avaible wood,
and my splitter is not as much HP and using a 4" cylinder, I have at time wondered if one could connect a second cylinder at could be kicked in and out and only used when needed to power through the nasty's on a standard 8" diameter round it will usually power on through if not a knot or crotch of a tree, many times tho it will not come apart as there are strings of wood still connecting each halve.
set up with two valves one power beyond or some thing to run the second cylinder just make so it would come in and hit a notch so it would not cycle ever time, but still be secure in it push,
/ Eucalyptus splitter. #4
As a side note to splitting twisted/knotty wood, I try and make sure that I split from the BOTTOM up as the tree grows. You get curved slices out of your wood sometimes, as the wedge splits the wood as it grew and branched out.
Thx Baby G!
Thanks to the others for advice.... I agree about splitting with the way the tree grows
/ Eucalyptus splitter. #6
I find that if I have one hard to split, it is easier to just cut it up with a chain saw.
If I had lots like that, my thinking would probably change.
I once knew someone who called it "you caly peet us.'
Bruce
/ Eucalyptus splitter. #7
With a single wedge, I think our 5'cyl should split thru just about anything/ I use a 5' cyl and never have a problem on 30" dia rounds, splitting 4ways. I recently added another wedge for a 6way split and it doesnt hardly slow down on anything I put thru it. Sweetgum, Ash, Whiteoak, locust, it doesnt matter.
/ Eucalyptus splitter. #8
If you check the "Log Splitter Wedge ripped off" thread, you can see how I did my wedge system. (No since boring folks by having them read the same info twice.)
/ Eucalyptus splitter. #9
I gave up spitting American Elm on my 27-ton splitter. It will do it, but the wear and tear of splitting a load of Elm is just not worth it to me. Tried splitting it when green and when dry and it mostly just slowly sheers through the wood rather than splits. On the other hand, what I have left from two years ago hasn't rotted any, so I might just cut it into cookies and burn it that way. If someone tries to give me elm now, I politely refuse it.
/ Eucalyptus splitter. #10
If I ever visit up north again, I think I will try and find a piece of elm , bring it home and see what all the fuss is about. . I have split oak, hickory, ash, oaks, and just about everything else that grows around here. Often use the splitter to shear off a short piece if the round has been cut to long to fit in the splitter. I find it hard to believe that anything can be so hard to split that people wont use it for firewood
Sounds to me that elm and euc are on the same level of toughness!!
/ Eucalyptus splitter. #12
Well,it's not that bad to burn if you can get past the stink.My first encounter with elm was back in the 80's.Local contractor gave me a tree for free that was close by and I was thrilled until I tried to split it.Elm does not actually split,it just rips apart in strings.The fibers run the length and do a twist pattern like a woven rope.The only wood around here that even comes close is pin oak and it's a whole lot easier than elm.
/ Eucalyptus splitter. #13
There is an easier way to do this: If you plumb it so that the bottom and rod sides of the piston are connected, and pressure is applied to both sides, you effectively push only with the surface of the rod diameter. When the going gets tough the connection between rod and bottom side is shut and the rod side flows away to the tank like it would normally do, so you have the full power of the cylinder again.
/ Eucalyptus splitter. #14
Normally after the first split the rest of the splits in elm aren't to bad. I just don't like the moving around the stringy pieces. Any elm over 20" gets noodled into 4-6" wide strips. These split real easy & are not near as stringy.
Have you decided on the design for your splitter yet? We are looking forward to progress reports/pictures of your build. :)
/ Eucalyptus splitter. #15
It is a while since I saw somebody write this info. I always thought it gave the reason for "You cut a tree down, and then cut it up."
/ Eucalyptus splitter. #17
I have no elm issues when splitting below freezing. Red Elm is awesome. White stringy elm is not. Split cold and it's tolerable.
/ Eucalyptus splitter. #18
I think the elm I have here is White/American elm. The Dutch Elm Disease gets them before they get to 12" usually.
I leave the live ones alone whenever possible, you never know when one will be naturally resistant. Slim chance, I know.
Those I have had to cut are mostly 10" or less and are unsplittable with my 8lb splitting maul. Just bounces off and hardly makes a dent. I have to try, one of these days I might get lucky. :laughing:
/ Eucalyptus splitter. #19
Hard to explain. We are talking about wood splitters, and most wood will SPLIT after the wedge goes in a short distance. With Elm, The wedge just keeps encountering resistance as the fibers of the wood are sheared, but it is very resistant to just popping apart like most hardwood. The word "Fibrous" comes to mind.
Around our property, most of the elm we've ever cut was standing or falling dead, and therefore fairly dry. I'd say 12" is the about the biggest we encounter at the base of the tree. Yes, wait till January and it pops open much easier.
TB
/ Eucalyptus splitter. #20
Red Gum is one of the most sort after fire woods around here 25 ton rams will handle nearly everything.
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2011 TAKEUCHI TB153FR EXCAVATOR (A65056)
2011 TAKEUCHI...
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
NEW HOLLAND 1725 FORD TRACTOR (A65057)
NEW HOLLAND 1725...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
