Best tire chain style for snow?
/ Best tire chain style for snow? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
I find that this site, with a lot of people's experience is a good shortcut to getting an education that would otherwise take a lot of time and money. :banghead:
Summer flew by and I didn't complete all of my land clearing project, it looks like I'll be draging logs this winter with the JD 5075. I'm mostly concerned about traction when we get a foot or two of the white stuff. Is there a chain style, that's best (or a "best-per-$) for snow on these 16.9-28 tires?
Double ring? V-bar? (What does that mean), the type you see on skidders? With/without vertical bars/lattice?
/ Best tire chain style for snow? #2
Don't see anything except ladder chains here. Many are going every other side link instead of every 4th to get more chain on the ground.
/ Best tire chain style for snow? #3
Tractor Tire Chains, Tire Chains & Studs, Tires & Supplies ...
GEMPLER'S - Outdoor Work Supplies, Spray Equipment, PPE & more Tires & Supplies Tire Chains & Studs
Tractor tire chains help you operate in tough weather conditions. Shop GEMPLER'S for DUO-Grip and FTH-style tractor tire chains for added stability!
Just some examples. The uglyier they look the better they may work:D
/ Best tire chain style for snow? #4
I just bit the bullet and bought a set of Aqualine Talon chains for my Branson with 17.5LX24 R4 tires. They are quite expensive (1200 dollars) but I'm getting too old to be sliding down my long 800 foot downhill driveway, and I'd like to spend a few more years on this earth. Google them and I think you'll like what you see. Most tire chains sink between the lugs making them useless. You need some that will keep the tires in traction with the ground. They're not for hard surfaces as you can see. Good luck.......
/ Best tire chain style for snow? #5
Best value for my money was with tractor tire chains for farm tractors
aka tirechains.com
I went with the DuoGrip style - best match for my needs. Helps keep the chains out of the valleys when running deep lug tires. Adding Vbars would have made for more aggressive bite, but I left them off for the bit of pavement use they see.
Pics at the above link and what the other poster linked should help you understand the chain styles.
IMO, some key questions:
1) Flat land or hill use ?
2) How much glare ice do you get ?
3) Rear chains only, or are you doing all 4 ?
3) Do you have pavement or concrete ? If so, what level of surface scratching/gouging can you live with ?
Answering most/all of those should nudge you in the right direction.
Rgds, D.
/ Best tire chain style for snow? #6
There is really no serious traction in snow. The traction happens after the tire digs to the bottom of the snow and encounters dirt or whatever.
The studded or v-bar chains will give you some serious traction but they also chew up concrete and asphalt, even with no slippage.
Your 5075e might get along okay in the woods without chains if you pick your day for good snow conditions, and keep a lane to the hitch points in the woods cleared so the snow doesn't get too deep. Don't know if that is feasible for you or not.
Other than that, I'd drop and drag trees close to the wood shed now before chains are needed, then work them up later. You should have month or so. :)
/ Best tire chain style for snow? #7
I've got studded ice chains, pretty much the same as the Aquiline Talons. Great working chain, but as the guys mentioned not good for hard surfaces. Not that the chain won't work on them, but they chew it up. Mine are Norse Super Tractor, made in Norway I think.. by a company named Tellefsdal. They were about $550 for 11.2 x 24 AG type tires.
I run them loose, as recommended by the manufacturer. They've never come off, there's no way they can really unless something breaks. I'm on the 4th winter with them now, no signs of excessive wear yet.
Sean
/ Best tire chain style for snow? #8
I ran the V-bar chains on my Kioti CK30 for plowing snow. For our 1/4 mile dirt road that often got icy, they were a must have. It seemed as long as I waited until the ground was frozen solid, I didn't have any issues using them on my asphalt driveway. If the ground wasn't frozen, the driveway was too soft to handle the chains. YMMV
/ Best tire chain style for snow? #9
This subject usually has huge debate. But actually the best traction in snow is running on top of a layer of snow. the traction is gained by the tire gripping and compacting snow and rubbing it against the layer of compacted snow under it. The friction between the two layers of snow is what creates the traction. I.e., snow tires with very small sipes rather than huge open lugs. :)
I have 2-link bar chains for my tractor that work very well. Bought them used from the local governmental organization that ran them on a road grader. Very cheap chains indeed.
But as said above, the uglier the chain, the better they work. And as said above, tirechain.com is a good source of information and pricing.
Post when you buy some and show us pics. We love pics. :)
/ Best tire chain style for snow? #10
Considering the intended use, I should have mentioned that mine have been used in the woods every year cutting firewood, worked well. The trouble with many design is that the chain can hide between the tire lugs and do nothing. Net or ring style chains prevent that, though I wouldn't recommend solid rings (bear paws) because of poor ride quality and their tendency to "slip and grip". The all-chain type conform to the ground profile and grip better.
Sean
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
(INOP) MASSEY FERGUSON 263 TRACTOR (A59823)
(INOP) MASSEY...
1991 TRAILMASTER CRUDE TRAILER (A60736)
1991 TRAILMASTER...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
