1997 F150 transmission issue
/ 1997 F150 transmission issue
Update- I was able to get some lift time at my mechanic's shop last night. I was able to find a couple issues- a lot of clutch debris (black powder, burnt smell) in the fluid and I replaced the tp sensor. I serviced this trans 10k miles ago but went ahead and did it again. Od light still blinking but shifting better. He has a 2002 reg cab F250 XL with a 7.3 auto 4wd sitting in the back of his shop with only 43k miles. Cloth seat rubber floor cruise control. Manual locks and windows. A customer brought it in 2 years ago for new axle seals, lost his job and could not pay the bill. He signed the truck over and then died about 6 weeks later. The truck just gets in the way. I drove it and it runs/drives great. Everything works, needs tires. He told me give him 6500 and its mine. Thoughts?
/ 1997 F150 transmission issue #42
4x4 diesel for $6500. Buy it!
Chris
/ 1997 F150 transmission issue #43
i agree.. buy it or post it's wherabouts. ;)
/ 1997 F150 transmission issue #44
If I were you, and this was a trusted mechanic, it would be sitting in my driveway already. I'm a happy 7.3 owner myself.
(I'm asssuming that down your way the body will be good to very good. Usually not the case where I live.)
Rgds, D.
Rgds, D.
The body is in good shape. A few scratches, no dents. How about the auto trans from that year? I dont want to spend 6500 vs 1800 then have to rebuild a trans again in a year. Not sure what truck was used for, no hitch in bed or signs of one ever being there.
/ 1997 F150 transmission issue #46
if it was not used for heavy towing it may be minty.
my 99 f450 WAS for sure used to tow and it has it's oe tranny in it. I suspect my 99 350 has it's oe tranny as well.. and it also has a gn hitch and plenty of evidence bumper pull was used a bit.
/ 1997 F150 transmission issue #47
My 2001 has a Ford Reman. trani in it, but was used as a City of Toronto heavy service vehicle. Mine has the 4R100 trani in it, yours may be the same model.
Given regular trani service on a stock vehicle, they seem reasonably durable. Other than neglected fluid and towing abuse, the other problem area (trani wise) can come from if the truck has been turned up - ie. maxed out with a high output tuner.
If it feels right to drive, and the Trani fluid looks/smells decent on the stick, I'd go for it.
I added a trani Temp gauge to my truck pretty quickly (not stock on the vans), make sure it's working on this p/u.
Not trying to spend more of your money.... but other than the motor oil, I'd change the Trani fluid/filter, and coolant ASAP - unless your trusted mechanic can report recent work.
Some guys upgrade the trani cooler on the 7.3 to what the factory used on the 6.0. I plan to upgrade mine, before next RV towing season here. The 6.0 part is said to be a good quality/capacity cooler; I may end up with a decent aftermarket one though, just on price.
I'm not saying the 7.3 has a known bad T cooler - just that a higher capacity one had to be spec'd for the 6.0, and as time moved on, higher capacity ones became more common in the aftermarket. Esp. down your way, I can't imagine it's easy to go too big with a Trans. cooler.
Let us know how this goes, and if it does follow you home - Pics Please ! :D
Rgds, D.
Rgds, D.
The axle seals was the the first time my mechanic worked on the truck. He is the go to guy for all the local diesel repairs, has a good rep for fixing and bullett proofing the 6.0 diesel. I oferred him my F150 and 4k cash. He knows my truck well as he has worked on it and my other trucks for years. He said he will mull it over and let me know soon. He has a 7.3 in an older ford pushing 400k miles on the original motor, a 96 I think.
/ 1997 F150 transmission issue #49
I'd buy it.
FWIW: I just traded my 03 F-150 because the trans dropped out. Check the fluid level 2 weeks before and looked good, no burnt smell. Driving home with the kids from shopping on Columbus day truck started doing what you are describing. Then a few miles later when in OD it wouldn't do anything the engine would only rev, no movement. Got home and the fluid had a burnt color and smell. I could drive it with the OV locked out, so I drove down to a dealer and traded that day. Next day went to go to work and had no drive.
Had to drive to the dealer in 2nd to pick up my new truck. Had it not been for the salt the truck has seen from all the NY winters I would have had the transmission rebuilt or swapped. The body was getting very bad and I planned on trading in spring anyway.
Truck had 143000 miles, and yes I told the guys when trading it the truck had trans issues.
/ 1997 F150 transmission issue #50
Good luck with the deal. Your mech can swap a used trani into your existing truck fairly easily - for many of us that is a PITA job - so he may go for it.
7.3 is a good choice, esp. if you hang onto your vehicles for a while. I've driven the new 6.7's - a blast to drive, but IMO kind of like dating a supermodel - way too costly for my wallet. Many guys driving the new diesels don't hang on to them much past the warranty period.
Rgds, D.
Update. I changed the egr vacuum solenoid and tps sensor. The weird shifting stopped but the o/d light is still blinking. There may be an internal sensor malfunctioning. The trans does not seem to be slipping, so I am holding off on the rebuild. Btw, if you have to change the tps on this model, be careful with screws. They are held in with loctite from the factory and it is easy to strip. I did, therefore got them out and upgraded to allen head per some online research. Attached a pic for reference. The 7.3 did not work out. He decided to keep it. He has 14 yr old son and it will be his at driving age. Took him 2 weeks to decide this.
/ 1997 F150 transmission issue #52
That egr code is usualy caused by anfaulty DPFE sensor.
As for the OD light flashing, there should he a trans. code stored. The transmission range sensor and connector upgrade are a common problem, and sometimes wont set a code. This is mounted to the side of the trans on the selector shaft.
You may want to have a trans shop or dealer check for codes and range sensor.
As mentioned also check for leaking windsheild, or roof body seam sealer leaking, it will leak on the GEM module/ fusebox asy, this can cause some strange electrical problem's.
Dave
/ 1997 F150 transmission issue #53
Dave
OH YEAH it will.. :)
Where is it located? This might explain a few things.
/ 1997 F150 transmission issue #55
look inside drivers compartment beside your left leg. that's wher ehte fusebox is in most f series trucks. back sid eof the power distro center is the gem module.
I had a leaking lmap on the top of my cab when i first got my f350.. it ran water downthe pillar and fileld the gem up.
literally.. it 'sloshed' when you shook it.
i had blinking od lamps. power door locks that automatically randomly locked nad unlocked. gauges htet worked or did not work.. dome lamps and interior lamps that did or did not work including open door side lamps..e tc.
wet gem on a ford cripples it electrically.. :)
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2021 Ram 5500 4x4 Palfinger PSC 8029 4 Ton Crane Mechanics Truck (A61568)
2021 Ram 5500 4x4...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Trava Long Gooseneck Livestock Trailer (A64047)
Trava Long...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
