1997 F150 transmission issue
/ 1997 F150 transmission issue #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
I have asked a lot of questions here about this truck and have received great feedback. Here recently, the od light had started blinking and the trans seems to be "downshifting" and "upshifting" in overdrive. Engine rpms jump from 1600 to 2000 and back again every 15 seconds or so. I also noticed the speedo indicator is a little jumpy. It feels like the tourqe converter is locking then unlocking continuosly. Any thoughts? The truck is 4wd, 4.6 V8.
/ 1997 F150 transmission issue #2
Gonna have to get it scanned and see what the code is. Anything before that would be a guess.
Autozone will pull codes for free.
Apologies. Did this already- nothing showed.
/ 1997 F150 transmission issue #4
That's odd. Does the speedo jump while the od light flashes? If so, I'd be very suspicious of the VSS in the rear diff.
Generally generates a P0500 code.
Sometimes the wires break at or near the connector. Also take a good look see at the terminals. Have seen them get corroded and loose continuity.
Yes it jumps, kind of "shakes".
/ 1997 F150 transmission issue #6
Take a good look at the 2 pin connector on top of the rear diff.
If it looks fine I'd just put a VSS in it if it were mine. Used to be real cheap. Get it from the dealer if you can.
/ 1997 F150 transmission issue #7
I would take it to a trans shop for a scan. More than likely its a sensor or valve going or a broken wire as Peacock stated.
Chris
Found the sensor, unplugged it and blew it out. How hard is it to swap out? Looks pretty easy.
/ 1997 F150 transmission issue #9
Easy. 1 bolt. Thinks it's an 11mm.
Look at the terminals real close with a bright light.
Found the part, $38.69 at Ford. Will change today and report back. Would this sensor cause the trans to shift like described above?
/ 1997 F150 transmission issue #11
Very well could.
The VSS input is used for a multitude of transmission controls. From EPC solenoid duty cycle to TCC valve duty cycle to shift solenoid managing.
Peacock said:
Very well could.
The erratic shifting started when light started blinking, so hopefully this is it. Thanks for all the help!
Well darn. The needle still twitchy, shifting weird and the o/d light is blinking still. Is there a speed sensor on the trans tail shaft?
/ 1997 F150 transmission issue #14
If no code is showing, or if it was and you read it, disconnect both battery terminals and give them a good cleaning.
It's a good thing to do and it will reset your system. If the issue still persists, it has to be storing a code.
The VSS's do go bad so it was a good thing to replace anyway. Reset your system and see what happens next.
/ 1997 F150 transmission issue #15
does that model have a GEM module?
the gem in my 99350 got wet from a leaky canopy lamp base.. and gave me a twitchy rpm needle and blinking od lamp
/ 1997 F150 transmission issue #16
the frist thing i would check is the speed-o sensor, i would think the tranny is comp. controlled, if it is't getting the right info about the truck speed, then it will go nuts
/ 1997 F150 transmission issue #17
Take it to a repeatable shop and have them scan it. Those clowns at the parts stores don't know what they are doing.
/ 1997 F150 transmission issue #18
Had a 1997 f150 that did the same thing after it had 100,000 miles on it. At that time the shop that worked on mine said this was common. Their solution was change the fluid and put in some type of additive. This worked for several thousand miles, but was starting to return when I traded it.
/ 1997 F150 transmission issue #19
that sounded like a slip.. and they put in a friction modified fluid.
not sure this si the same issue with a blinking OD lamp...
/ 1997 F150 transmission issue #20
Speedo/instrument cluster?
Possible ECM.
Be sure to check all the others, wiring, sensors etc.
