Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #1,821
Roy- I have a V-plow very similar to your new one, on a 620i. Works great -- the gator is so maneuverable. I use about 400 pounds of weight in the bed. (Sand bags).
My "new one" is actually about 3 or 4 years old...just new to me.
Do you use skid shoes?
I'll be using sand bags too. The guy I bought the plow from said he used 80 lbs of weight as ballast. I'll probably go at least that and have a shovel in the bed in case I need some sand for traction.
/ Pictures of your snow weapons #1,822
Ok how did I screw this up? I have no tractor projects that I can't do with one of my uncles tractors so I decided to get my John Deere ready for winter. I hooked up the new snow blower the other day, ran the power for the rotation and deflector that works all I have left is to cut the PTO shaft which I plan on doing on my day off. Today I needed some fresh air and decided to attach the snow plow to the front. Ok I have done this before no problem right? The plow is hooked up to my loader arms and the angle is attached to the hydro for the bucket curl. Every thing hooked up bucket angles as it should but the loader arms will only rise about 4 feet. Checked fluid and it is OK. Roy I believe you had an 855 at one time any idea?
Sent from my iPad using TractorByNet
/ Pictures of your snow weapons #1,823
I never had an 855....buddy of mine did and it was the first "modern" tractor I drove as well as the first hydrostatic.
Anyway, do the easiest thing first...disconnect your hydraulic lines and reconnect. If it worked before, there's no reason it shouldn't work again.
It's possible one of the QD fittings is sticking.
/ Pictures of your snow weapons #1,824
Tomorrow's project. Thanks Roy
/ Pictures of your snow weapons #1,825
Good luck and let us (or PM me) know if it works OK.
I assume you had no problems with the loader before rigging the plow?
/ Pictures of your snow weapons #1,826
No none. I used it before taking bucket off.
/ Pictures of your snow weapons #1,827
Yes- I like to have the skid shoes on there. Our driveway is dirt/gravel. After a few storms the surface gets very hard, but until then the skid shoes do help.
/ Pictures of your snow weapons #1,829
Thanks Roy, disconnected all hydro lines and reconnected one at a time, started it up and all works. Thanks again David
/ Pictures of your snow weapons #1,830
Roy, disconnected and reconnected each line one at a time, started the tractor and every thing back to normal. Thanks David
/ Pictures of your snow weapons #1,831
Outstanding!
/ Pictures of your snow weapons #1,834
Just upgraded a few weeks ago from a 10/29 Murray walk behind to this JD 455 with a 47" blower and a heated cab.... can't wait for some snow :)
/ Pictures of your snow weapons #1,835
A few more minor tweaks and perhaps a 3ph and blade and I should be all set to go!
/ Pictures of your snow weapons #1,836
It looks like you are the snow boss of the burb. How you gona keep all the neighbors from mooching off your time and money?
/ Pictures of your snow weapons #1,838
Our first tractor/blower set up.....2008 New Holland TL100A with a brand new 92-280 Inverted Normand blower. Bring on the snow....after all of our digging jobs are done. :)
/ Pictures of your snow weapons #1,839
That there be cheatin, Yo-all aint givin the snow any chance atoll. :thumbsup:
/ Pictures of your snow weapons #1,840
I hope the snow doesn't stand a chance! :) That was the idea. One of my accounts is a large HOA Subdivision/Country Club and Golf course. We get a LOT of drifting out here. Plowing is ok, but I am always having to go out on peoples lawns, to get the snow out of the way. The tractor/blower will pretty much eliminate going off the roads, but I can still blow the snow right along the edge of the road or 50 feet out in the field or ponds.
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
wooden chair (A61569)
Gradall XL3100IV 4WD Rough Terrain Wheeled Excavator (A61567)
Gradall XL3100IV...
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
