new guy from Georgia
/ new guy from Georgia #1
skytime24
clarkesville georgia
LS G3038, stihl fs90, stihl ms290, snapper riding mower, Honda gcv160, Yamaha g9 golf cart
Hi everyone,
A few years ago my family inherited a 25 acre farm when my grandfather rolled an old snapper mower down a hill breaking his neck
Anyways I'm completely new to farming and have been lurking this forum for quite a while now.
The property is a 25 acre farm with a 1 acre pond. 2, 5 acre pastures separates by a creek. And 2 gardens.
I'm in the market for a tractor 4wd fel, I can buy implements separately budget 12k
Thought I'd finally signup
/ new guy from Georgia #2
Welcome and good luck with your tractor search. I'm fairly new here but you will find plenty of good people with lots of knowledge to help in your hunt. By the way I'm partial to GREEN
Sent from my iPad using TractorByNet
/ new guy from Georgia #3
Hi everyone,
First, welcome to TBN.
You will obviously need to be looking in the used market with a budget of 12K (unless you mean that you have a 12K implement budget which seems unlikely). Or, unless you are willing to take a loan to get a new tractor. Frankly, 12K is not a lot for a 30-40hp 4wd tractor that would be the minimum size you'd want on a 25 acre farm with 10 acres of pastureland to maintain. You don't tell us much else about what you intend to do with the farm but even just keeping it from returning to scrub forest will require at a bare minimum annual bush hogging and you'd need a bare minimum of a tractor capable of handling a 5 or 6 foot wide bush hog to do that. Realistically for a new CUT tractor in the 30hp size range you are looking at close to 20K new with FEL. Good news (relative) is that you can get 0% interest loans for five or six years from several manufacturers (Kioti, Mahindra, LS?) that make reliable strong tractors in that size range. Add another $4K or so if you want more famous brands like Kubota or JD or NH. The tractors are all reliable and have roughly the same features however so with a smaller budget I would recommend staying away from Kubota and JD just on lower bang for buck basis. Check out a few dealerships near by but don't be shy about purchasing from further away if you can transport the tractor. Used CUT tractors in the size range you'd need (30-40hp) are pretty pricey ($14-20K) and as they don't come with the 0% interest option are often not as good a deal as new. You might be able to find a higher hour higher horsepower and older utility tractor for your budget but you'd have to be prepared to do more maintenance so that might not be the greatest idea especially since you really don't need the bigger size.
If I were in your shoes I would scan craigslist, read a lot here on TBN about all sorts of tractor and implement issues, go visit local tractor dealers selling different color machines and do some soul searching regarding what sort of financial investment you are willing to make. If you can add a few thousand to your $12K stated budget you could get a good used 30-40hp 4wd tractor with FEL and under 500 hours on the meter from a number of manufacturers. Those used tractors would have a lot of life left in them so long as they had been properly maintained. If you think finances will open up down the road then it might not be a bad idea to take out a zero percent loan on a new tractor and put the 12K in the bank to make the monthly payments for a couple of years.
/ new guy from Georgia #4
G'day and welcome to TBN from Downunder.
I'm a GREEN fan too... but you'll have noticed that we don't tend to push any particular colour.
Enjoy the site!
On a tablet takes me forever to type on this thing. The cows keep the pasture I n shape . I have roughly 9 acres that need to be bushhoged monthly. Rest is woodland. I need to re grade the gravel road roughly 1/4 mile. Will need to hall firewood and gravel with fel. I've been thinking about the Ls g3033. When I said budget I meant how much cash was in hand
/ new guy from Georgia #7
I haven't seen one myself but I only hear good things about the LS G3033 (except for the seat). I would still compare it to the roughly equivalent Mahindra and Kioti.. Not sure exactly which Mahindra compares but with Kioti it would be either the CK 30 or CK35 or if you can stretch the DK35. Any of those should be fine for the work you have in mind. All would fit your budget if you were willing to take a dealer loan.
/ new guy from Georgia #8
:welcome:
Thanks everyone, what implements would I be limited to, I think the PTO ha 25 HP, can that run a post hole auger, I need to put a new barn up as the old one colapsed
/ new guy from Georgia #10
Sure you can run a PHD. At 25 PTO you can run a lot of stuff.
/ new guy from Georgia #11
As Murph noted, you can run just about any implement, you just need to choose the right size. For post hole auger there isn't a size issue so much as a speed of drilling difference but I cannot imagine 25hp will give you any trouble at all. You will need to pay attention to the size of boxblade (for your driveway) or bush hog. You could probably run either five or six foot implements. Make sure the boxblade is wide enough to cover your rear wheel track. If you have bush hogging of brush to do then choose a 5ft hog, if you are just cleaning up pastures then a six footer would do fine. You probably want "standard" duty implements with a 30-35hp tractor as getting "medium" duty is probably overkill and heavy duty is ridiculous and expensive. You might want to start looking in craigslist for used implements. Post hole diggers (PHD) are fairly common and are usually a good deal as they typically get used for a couple of projects then sit in a barn or field for years before being sold. A box blade is easy to assess as there are no moving parts. The bush hog ideally should be demonstrated by the owner but if it looks in really good condition I wouldn't worry too much. Check the gearbox oil, make sure the blades spin (slowly) when you turn the PTO shaft by hand with a bar, make sure there are not cracks or broken welds or anything but just surface rust. A few dents is par for the course, you care more about the blades and gearbox. Woods, Landpride, BushHog and Rhino are excellent mower brands. There are a number of smaller companies or slightly down scale mowers that can be good if the price is right. King Kutter, Kodiak fit in that category. If you find something you are thinking of going to see, post here and ask opinions.
Y'all are great thanks for the info as you know new to the tractor world, I've only driven and old ford 8n
I have pretty bad credit , I have a large retirement account I can't justify taking anymore out of it as my SS will be coming in in less than a year . I wonder if that'll help me get approved for finace
Aluminum Fifth Wheel Tripod (A61166)
Aluminum Fifth...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
JOHN DEERE 850J WH CRAWLER DOZER (A62129)
JOHN DEERE 850J WH...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
