Transmission shifter
   / Transmission shifter #1
Peterpiper
Member
Norfolk, Va.
Massey Ferguson 135
On my 70 135, the shifter doesn't seem to want to move over to the 2nd and 3rd gear position.
At this time, I am happy enough using 1st and reverse high and low and don't want to jinx that.
Seems like I have to completely remove the steering box to inspect?
Was just wondering if anyone had any thoughts?
Thanks,
Gary
I wonder if I can use a screwdriver through the fluid filler hole and dislodge something?
   / Transmission shifter #3
Why yes you can. That's how it's done when jammed. When both shifters are in neutral the detent boxes with be side by side. Think of your shifter as a lever that fit in those boxes.pull left and the lower part of the shifter example. First gear. Left box would be pulled back with a screwdriver.
Thanks Kid!
So, I took the fill plug off and noted that you can see things. I then worked the shifter over in the 2nd and third direction. After just a few pushes, it went into the 2nd and 3rd position. All is well now. Just hadn't been used for a while!
   / Transmission shifter #5
Thanks Kid! So, I took the fill plug off and noted that you can see things. I then worked the shifter over in the 2nd and third direction. After just a few pushes, it went into the 2nd and 3rd position. All is well now. Just hadn't been used for a while!
I didn't learn that from experience. I learned right here on this website :smile:
   / Transmission shifter #6
not sure if this transmission works off the same principals as the ferguson 40 we have, but if you ever find yourself locked in a gear doing the same basic thing with one rear tire jacked up will relieve pressure on everything and allow you to pop the shifter into neutral again. I know when ours locked into second I was worried but a old time farmer and repair man told us about it and it worked perfect. Hope it never happens but its good info to have it it ever does
8 Ft Fork Extensions (A50322)
8 Ft Fork...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A51039)
John Deere 752...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
TOOL BOX (A50854)
TOOL BOX (A50854)
