Welding drill stem
/ Welding drill stem #1
TEXHORN
San Antonio
Mahindra 5500
I've been lurking around the board, learning, for a while but have never posted.
Time has come to get a welder. I am leaning towards Everlast. My question is that I will mainly use it to weld used drill stem (fences, pens, chicken coop). I'm in the middle of the oil fields in Texas so plenty available. They can be rusty and magnetized. Is there one welder that will perform better then the other? Tips or tricks you can share.
Thanks
/ Welding drill stem #2
The PA-200 is fantastic with 6010! But if you can afford to buy the PA-300 you'll get adjustable hot start, and adjustable arc force. :cool:
/ Welding drill stem #3
Far as the magnetized pipe, an easy way to counter it is an AC welding machine with 6011. With a DC only welding machine couple tricks. First thing I'd do is wrap the ground lead around the pipe 4 or 5 times. If that doesn't work change directions of the wrapping. If that doesn't work, heat the weld zone to a dull red with a torch. I've spliced about a bazillion H-piles after being driven. All the corners in a H-beam will give you arc blow on the best of days, but after being driven they can be a nightmare to weld.
/ Welding drill stem #4
X2 on the PA-300:) I love mine. The hot start and arc force are great no sticking even for a completely rookie like me:cool:
/ Welding drill stem #5
You're probably only going to be using using smaller dia. rods so it might not pose too much of a problem. If it does, experiment with Shield arc's suggestions. You should be able to use a DC machine. I mistakenly welded a piece of 4" drill stem in to repair a drilling rig. The night shift foreman caught it and replaced it. I asked a laborer to find me a short piece of 4" pipe and he brought back a piece of drill stem, except I never knew it was drill stem. I cut it to length on a big chop saw. It didn't weld too bad and I was using 3/16" 7018 but enough I thought it could have been drill stem. The foreman was real good and didn't blame me. It took about 1/2 an hour to fix. After that they started marking the drill stem and putting it in a separate location from the other short pieces of pipe. Lots of fences made out of drill stem with DC portable welders.
/ Welding drill stem #6
for rusty and magnetized pipe ,my preference would be a ac welder and 6011 rods.
/ Welding drill stem #7
The worst thing about welding used drill stem is you have no clue where it has been or what it was used for. I know that you don't take a load of drill stem ends etc to a reputable scrap yard because they won't accept it without testing it for radiation. You wouldn't want a bunch of biohazard material around your house but with used drill stem you might be having something as bad if not worse.
Heavily magnetized material might take a bead but there are a lot of stories about it fracturing at the HAZ afterwards. Some old boys out in west Texas were sharing nightmares about welding H fixtures with it and they all had stories about the joint breaking, usually with a loud pop either during the welding or immediately afterwards doing the cool down. I never changed my welding machine, only use dc, when welding magnetized, I just accepted it was going to be a nightmare for the first couple of inches. I also never laid out a joint structurally where a break would cause a disaster when working with magnetized material.
For the reader not understanding the issue of welding magnetized, consider this. You are using a torch to weld and you have a strong wind blowing your flame away from one side or the other. You can never get the same heat on both sides at the same time. It can be frustrating when you watch your arc and puddle on one side refuse to get near the other side.
/ Welding drill stem #8
If you use 60xx rods on drill stem you will likely end up with a fractured weld. You need to use 7018 or higher grade of low hydrogen rods to weld that with. I don't think any welding machine will weld magnetized and work hardened material any better than another one. Just need to get one with the current capacity that you will be needing. I would not mess with any 110V machines even the inverter machines work better in 220V and have higher amp and duty cycles than the 110V ones. Lots of folks have used the 110v with satisfaction but they are not for heavy duty work like welding large diameter drill stem where you need 75+ amps and long duration in welding time.
/ Welding drill stem #9
I've never welded either drill stem (what exactly is it??) or magnetized material. Given Harv's description though, why wouldn't oxyfuel be the best way to weld magnetized material???
/ Welding drill stem #10
Just found this blurb in a 1988 Texas Monthly article about drill stem fencing:
"So now you’re convinced, right, and you want a drill-stem fence on your little ranch. Where do you get one? Well, first you need to know something else: These fences are not made with real drill stem. To quote Robert Brown, a former tool pusher for Gage and Moore, of Fort Worth, “A drill-stem fence? What do you got—elephants? Man, drill stem weighs two hundred pounds a foot. They call it drill stem, but what they use in them fences and barns and metal buildings is tubing.” Whatever it’s called, its fundamental purpose is to drill oil wells. The drill stem, which is about 4 inches in diameter, makes the hole; another pipe, called casing, sets the hole; the tubing, 2 3/8 inches or slightly larger in diameter, goes inside the casing; and the sucker rod works up and down inside the tubing to pump the oil or gas out. Never mind if you didn’t get all that; just order tubing when you build your fence."
/ Welding drill stem #11
Out of interest. Why are H beams driven at an angle as in the pic? What sort of construction is this?
/ Welding drill stem #12
I don't know what they're building in that picture. I found it on the Internet. When I was doing this kind of work there was no Internet, if I would have known I would have taken more pictures of the jobs I was on.:laughing:
We drove batter piles for container ship docks in the abutment, for the impact of the ships bouncing against the dock. A lot of it is done for uplift in earthquake zones also.
You can't see the H-piles in these pictures, because the time the pictures were taken the beams were already to grade.
/ Welding drill stem #13
I rather naively assumed that those were suspension bridge pilings or would be incorporated into some structure that would resist pull in the opposite direction from how the H beams are pointing. Massive tent stakes!!
/ Welding drill stem #14
Tent stakes? I like that!:laughing: Here are some pretty big tent stakes.
Thanks for the input.
I do have drill stem 4.5", 2 3/8 and 2 7/8 oil pipe and sucker rod. What we call oil tubing actually comes new in rolls and is thinner walled. The 2" pipe, commonly called drill stem around here is a heavy wall pipe that comes in 30' joints.
The rod is no problem. The others haven't been bad in the past bit do have some hard or slightly magnetic spots. Those will kill a cold saw blade in a second when cutting.
/ Welding drill stem #16
Wow, those are massive tent stakes....:shocked:
/ Welding drill stem #17
Yea, I understand they are for a tent that needs to be big enough to cover all the BS coming out of Congress these days! Ought to be at least as big as one of the pyramids in Giza.
/ Welding drill stem #18
Biggest I ever drove. 10-feet in dia. All of them had to be welded on to. Can't remember all the lengths, but the ones farthest off shore were driven over 200-feet into the river bottom then drilled out, and filled with concrete.
/ Welding drill stem #19
How do you "drill out" massive H beams that have been driven 200 feet down??? Are you saying that the steel was literally drilled away and then concrete poured in its place or was concrete poured around the steel? I have always wondered how the concrete got "attached" because you typically just see steel being driven.
/ Welding drill stem #20
:laughing:
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
8ft. Teak Wood Table (A61569)
8ft. Teak Wood...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2013 Larson LXI292 29ft. Boat with 30ft T/A Loadmaster Boat Trailer (A61569)
2013 Larson LXI292...
Electric Concrete Mixer (A61166)
Electric Concrete...
1043 (A60430)
1043 (A60430)
