JD LT150 Transmission growling
/ JD LT150 Transmission growling #1
nstardave
Ferndale, WA
John Deere LT-150
I have a 2004 JD LT150. Yesterday, after about 2 hours of lawn work, a growling noise started intermittently when I would go either forward or reverse. I got it to the garage. The drive belt is very worn and the pulley with the fan blade above the transmission is very loose. Could this simply be the belt or does the loose fan blade indicate other worn parts. Thanks for anyone's feedback and advice.
/ JD LT150 Transmission growling #2
Does the noise stop when you push in the brake?
/ JD LT150 Transmission growling #3
I have somewhat the same complaint -
Neighbors LT150 starts perfectly but will not move in either forward or reverse. I can use the drive-disconnect lever to disengage the transmission, but it will not engage. All I am getting is a growling noise when I attempt to move the tractor. I have attempted to manually reset the lever at the top of the transmission with no result. The noise DOES stop when I push the brake. Is there an adjustment I can make in the disconnect lever?
Thanks for any help!
/ JD LT150 Transmission growling #4
It might be the teeth on the pulley on top of the transmission are stripped.
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2011 Ford F150 (A64194)
2011 Ford F150...
