JD LT150 Transmission growling
   / JD LT150 Transmission growling #1
nstardave
Ferndale, WA
John Deere LT-150
I have a 2004 JD LT150. Yesterday, after about 2 hours of lawn work, a growling noise started intermittently when I would go either forward or reverse. I got it to the garage. The drive belt is very worn and the pulley with the fan blade above the transmission is very loose. Could this simply be the belt or does the loose fan blade indicate other worn parts. Thanks for anyone's feedback and advice.
   / JD LT150 Transmission growling #2
Does the noise stop when you push in the brake?
   / JD LT150 Transmission growling #3
I have somewhat the same complaint -
Neighbors LT150 starts perfectly but will not move in either forward or reverse. I can use the drive-disconnect lever to disengage the transmission, but it will not engage. All I am getting is a growling noise when I attempt to move the tractor. I have attempted to manually reset the lever at the top of the transmission with no result. The noise DOES stop when I push the brake. Is there an adjustment I can make in the disconnect lever?
Thanks for any help!
   / JD LT150 Transmission growling #4
It might be the teeth on the pulley on top of the transmission are stripped.
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
1994 CATERPILLAR CP-563 PADFOOT ROLLER (A52706)
1994 CATERPILLAR...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
New/Unused 20ft Bi-Parting Iron Gate (A54865)
New/Unused 20ft...
