Price Check Kubota MX5100 HST
/ Kubota MX5100 HST #21
I agree, nice to have two remotes, and 3 is best if you can swing it. I agonized over number of remotes because I was already beyond my "budget" for the tractor, so I went with 2. Now after year and a half with the tractor, it is clear that for me 3 would have been worth it. I could have just about paid for the 3rd remote (sort of) by spending even more money on a top and tilt instead of getting a cylinder for the tilt on my rear blade, and then come out ahead on the next implement that would use the tilt. But I didn't know what I didn't know...
Pretty much how I learned, got two rear remotes on our M8540 in 2010 thinking that would be plenty, when I bought the L5740 last year I went with three, of course I neglected to get any with float and didn't get third function either, live and learn.
/ Kubota MX5100 HST #22
1st set is a must, 2nd set is a luxury in that class tractor. float preferably on that 2nd set... a MX is definitely not a large acreage ag tractor, you cant even buy an OEM cab for it lol
It is what it is , a small utility tractor and a Kubota lol
/ Kubota MX5100 HST #23
Cab? What's a cab?
/ Kubota MX5100 HST #24
That price seems about inline with my local dealer. Alot of Kubota owners say the MX4700/MX5100 are the "sweet spot" in the Kubota line.
I agree on the remotes.... Try to negotiate a set or two. If you ever treat yourself to a grapple you'll need some kind of remote setup, and it's nearly always easier & cheaper to add them up front.
/ Kubota MX5100 HST
Im back. To answer a few questions, Yes I have looked at other brands. JD doesnt have anything I liked. Branson dealer is a jerk- told me I was a "hassle". I did like the Branson but wanted HST and cannot find a 4720HST. Kioti is nice but too far away. MF too pricey. So Im back to Kubota. The remotes I haven't thought about, didn't know if I would use them. I am getting a 3rd function for the FEL to operate a grapple, about $1000. And the FEL is QA. So MX5100 HST, FEL with QA, R4 tires loaded with water and antifreeze 26535.20 delivered + 3rd function. Sound good?
/ Kubota MX5100 HST
TSO how do you like the LS? They look nice, havent priced one.
/ Kubota MX5100 HST #29
That's in line with the numbers we came up with a hypothetical MX-5100 in another thread recently....sounds like a fair price.
/ Kubota MX5100 HST
Thanks everyone, different line of thought. What kind of fuel consumption can I expect out of a tractor this size? I was looking at smaller tractors before and was seeing 1.5-2 gal an hour. Is this good? I assume the MX5100 would be more but how much? Anybody know?
/ Kubota MX5100 HST
Also any opinions on buying now or waiting for the new MX5200 with the new emission stuff? Should I be concerned about buying now?
/ Kubota MX5100 HST #32
My Kioti DK-40 is about .8 gal per hour at PTO speed.
/ Kubota MX5100 HST
That's sounds low. The only #s I had seen was Branson 1.7 on a 3510HST and 2.1 on a 4020R. I haven't found #s on Kubota's web site.
/ Kubota MX5100 HST #34
Buy Now! I would not want the new emission crap myself.
/ Kubota MX5100 HST
That's kind of my thinking. Less stuff to mess up. I was only thinking maybe less smoke, although I haven't seen any smoke on any new tractors Ive looked at.
/ Kubota MX5100 HST #36
Yes, the newer tractors don't smoke, or smoke Very little. They already are very clean running!
I'll likely be looking for a low hour used MX5100 sometime in the next two years.
/ Kubota MX5100 HST #37
Agreed! The new emissions stuff will probably rob a little power too, while costing you more money. Get tier 3 (or tier 4 interim) if you can.
As for fuel consumption, stepping up to a 4cyl from a 3cyl will burn more fuel. No way around it. The mx5100 is turbocharged tho, so maybe that'll help.
/ Kubota MX5100 HST #38
Fuel consumption varies depending on what you're doing. When doing work with the rear blade I use about 1 gallon per hour. Splitting wood I run around 1300 to 1500 rpm and it seems slightly less. Backhoe at 2000-2500 rpm is at least 1.5 gal/hour. At idle its a lot less than a gallon per hour. For 8 hours work, I like to have 10 gallons available. ("Your mileage may vary.")
/ Kubota MX5100 HST #39
Also I should mention that my unit is HST, and I pay a lot of attention to the throttle. I drop down to idle whenever possible, even if just for a few seconds.
/ Kubota MX5100 HST #40
I traded in a perfectly good L5030 HSTC last year with only 1400 hours for an L5740HSTC to avoid the new L60 Series. I like cleaner air, but not the cost and other changes.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2016 Ford F-450 Utility Flatbed Dump Truck (A59230)
2016 Ford F-450...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
