Price Check Kubota MX5100 HST
/ Kubota MX5100 HST
Also any opinions on buying now or waiting for the new MX5200 with the new emission stuff? Should I be concerned about buying now?
/ Kubota MX5100 HST #32
My Kioti DK-40 is about .8 gal per hour at PTO speed.
/ Kubota MX5100 HST
That's sounds low. The only #s I had seen was Branson 1.7 on a 3510HST and 2.1 on a 4020R. I haven't found #s on Kubota's web site.
/ Kubota MX5100 HST #34
Buy Now! I would not want the new emission crap myself.
/ Kubota MX5100 HST
That's kind of my thinking. Less stuff to mess up. I was only thinking maybe less smoke, although I haven't seen any smoke on any new tractors Ive looked at.
/ Kubota MX5100 HST #36
Yes, the newer tractors don't smoke, or smoke Very little. They already are very clean running!
I'll likely be looking for a low hour used MX5100 sometime in the next two years.
/ Kubota MX5100 HST #37
Agreed! The new emissions stuff will probably rob a little power too, while costing you more money. Get tier 3 (or tier 4 interim) if you can.
As for fuel consumption, stepping up to a 4cyl from a 3cyl will burn more fuel. No way around it. The mx5100 is turbocharged tho, so maybe that'll help.
/ Kubota MX5100 HST #38
Thanks everyone, different line of thought. What kind of fuel consumption can I expect out of a tractor this size? I was looking at smaller tractors before and was seeing 1.5-2 gal an hour. Is this good? I assume the MX5100 would be more but how much? Anybody know?
Fuel consumption varies depending on what you're doing. When doing work with the rear blade I use about 1 gallon per hour. Splitting wood I run around 1300 to 1500 rpm and it seems slightly less. Backhoe at 2000-2500 rpm is at least 1.5 gal/hour. At idle its a lot less than a gallon per hour. For 8 hours work, I like to have 10 gallons available. ("Your mileage may vary.")
/ Kubota MX5100 HST #39
Also I should mention that my unit is HST, and I pay a lot of attention to the throttle. I drop down to idle whenever possible, even if just for a few seconds.
/ Kubota MX5100 HST #40
I traded in a perfectly good L5030 HSTC last year with only 1400 hours for an L5740HSTC to avoid the new L60 Series. I like cleaner air, but not the cost and other changes.
Komatsu HM400 (A60462)
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
CAT 930M (A58214)
CAT 930M (A58214)
2009 PETERBILT 340 (A60736)
2009 PETERBILT 340...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
