GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs #172
My old 160,000 mile 2003 crew cab with the 6.0L will smoke the tires even with the 3.73 gears after programming out the torque limiting.
   / GM unveils new 6.2 1/2t specs #173
My 2005 has a programmer.. I grew up with v8 trucks and muscle cars. I always assumed diesels were slow.. That is until I got my 05.. I was pleasantly surprised at the power when stock.. I was downright blown away after the programmer.. It's a big heavy crew cab 4x4 and it will smoke the tires in four wheel drive.
   / GM unveils new 6.2 1/2t specs #174
Are you saying it will smoke 3-4 tires at once empty on launch? If so this would be impressive. Are you sure the source of the smoke isn't coming out the exhaust pipe?
   / GM unveils new 6.2 1/2t specs #175
Lol! Yes, I'm positive...
   / GM unveils new 6.2 1/2t specs #176
Once you realize the numbers these engines put out when tuned it's not so surprising... This is NOT my truck, but mine is similarly equipped.. 427HP, 680TQ https://www.youtube.com/watch?v=CxYORy_LrH4
   / GM unveils new 6.2 1/2t specs #177
You won't just need new Michelins if you keep doing that!:laughing:
   / GM unveils new 6.2 1/2t specs #178
I am still surprised but don't have that much experience with 4x4's at launch. I would just think that is a lot of traction capability to move the truck forward more than spinning the tires quickly enough to smoke. I would have imagined possibly "chirping" the tires but not smoking them. Is your truck an automatic or are you dumping the clutch?
   / GM unveils new 6.2 1/2t specs #179
Automatic... It's the torque brother.. 570 ft/lbs stock off the dealer lot... It takes next to nothing to bump the torque up to almost 700 ft/lbs... Tires don't stand a chance to that much torque.
   / GM unveils new 6.2 1/2t specs #180
My 6.0 Powerstroke will smoke all 4 in 4 high and 4 low for a 100 feet if I let it. At 55 if I stomp it down the back end will brake lose. This is common on a late model chipped diesel.
Mine is a automatic also. Running about 550 Hp and 750 to 800 Ft Tq. At the drag strip with the truck at 7600# it ran 13.9 @ 98 mph.
Chris
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
