Series 3000 quits when Hot
/ Series 3000 quits when Hot #1
GTSRider
Gold Member
Cub Cadet 3000
After about an hour of perfect running... my series 3000 with
the 20hp Command engine, sputters and will quit.... then it will not restart untill cold .
Engine has 750 hard hrs. on it .... with recent new coil.... only one replaced.
What's going on here ?
Thanks....
Pete
/ Series 3000 quits when Hot #2
Have you checked for spark when it dies?
/ Series 3000 quits when Hot #3
If you have spark, pull the cap on the fuel tank when it dies. If you hear a hiss and/or it starts right up with the cap loose/off, replace the cap as the vent is plugged.
Aaron Z
No , I will check next time it dies... but it seems not to , as raw fumes, and smoke emege from tailpipe, when strter is cracnked after it dies.
Assuming it has no spark...what would cause this ?
New coil is about 6 weeks old. Would a faulty rectifier cause something like this ?
/ Series 3000 quits when Hot #5
You could have a bad coil.
/ Series 3000 quits when Hot #6
OP - could also have trash buildup under engine cowling causing heat buildup affecting coil....
Just quit again after 25 minutes of mowing... anyone have any ideas ?
No spark at all...but runs like new for the first 25- 45 minutes....
/ Series 3000 quits when Hot #8
Bad coil.. Bad spark plug (drives you nuts, had it happen 2x)... Change the plugs and coil(s).
Thanks.... I will change plugs first...and if that don't do it... I guess I will put in 2 new coils... but one is only about 6 weeks old...
possibly a defective new unit.... don't know.
Good tip....checked cylinders , and they are clear...dealer cleaned them when coil was installeed in August.
Going to install new plugs today...even though new in August....could be new defective...
/ Series 3000 quits when Hot #11
Well if it's not the coil, which I think it could be, maybe the replacement was defective too. The other possibility could be some kind of blockage in the fuel line.
I had some grass in the fuel line that would allow for good running for a time then sputter down and quit. After awhile the grass would loosen up a bit and the mower would run fine again.
It was the easiest fix I ever made, just to blow the fuel line out with air, but it took a longest time to diagnose it...very frustrating.
/ Series 3000 quits when Hot #12
Check source voltage to coils.
Update.... tractor went for 30 minutes , and then died, as it has ....
installed new plugs (Champion) , same as was in there... restarted, and ran like a new machine
for the remaining hour and a half !
Mowed 2 hours straight today.... perfect. The plugs that were in, had about 20 hr.s on them,
never experienced this before....coils are new with about 20 hr.s on them, so I was
baffled by the problem....but all is well now... thanks for the tip !
/ Series 3000 quits when Hot #14
Tell the truth, I dont like Champions.. had a couple either bad outta the box or fail quickly. I use NGK's now..
Glad its running good now.. Plugs are pain to diagnose :)
Yes.... I use NGK's in my vintage motorcycles.... do you have the NGK # ?
Thanks,
Pete
17395SFL (A61568)
17395SFL (A61568)
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2020 John Deere CP690 (A64126)
2020 John Deere...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
3097 (A63117)
3097 (A63117)
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
