Series 3000 quits when Hot
   / Series 3000 quits when Hot #11
Well if it's not the coil, which I think it could be, maybe the replacement was defective too. The other possibility could be some kind of blockage in the fuel line.
I had some grass in the fuel line that would allow for good running for a time then sputter down and quit. After awhile the grass would loosen up a bit and the mower would run fine again.
It was the easiest fix I ever made, just to blow the fuel line out with air, but it took a longest time to diagnose it...very frustrating.
   / Series 3000 quits when Hot #12
Check source voltage to coils.
Update.... tractor went for 30 minutes , and then died, as it has ....
installed new plugs (Champion) , same as was in there... restarted, and ran like a new machine
for the remaining hour and a half !
Mowed 2 hours straight today.... perfect. The plugs that were in, had about 20 hr.s on them,
never experienced this before....coils are new with about 20 hr.s on them, so I was
baffled by the problem....but all is well now... thanks for the tip !
   / Series 3000 quits when Hot #14
Tell the truth, I dont like Champions.. had a couple either bad outta the box or fail quickly. I use NGK's now..
Glad its running good now.. Plugs are pain to diagnose :)
Yes.... I use NGK's in my vintage motorcycles.... do you have the NGK # ?
Thanks,
Pete
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
Toro z turn (A56859)
Wooden Rocking Chair (A55853)
Wooden Rocking...
TANK MANIFOLD (A55745)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
