Intellipanel Display Setting
/ Intellipanel Display Setting #21
Please let me know what yours was set at. Thanks.
I didn't see this until I had already changed the setting....... but I think it was 2134????
Stu
/ Intellipanel Display Setting #22
Stu
Stu, thanks for responding. While I can't remember for sure, I believe that's what I was told was the R1 number. I wish I had the service manual to verify it though since I'm not 100% positive.
/ Intellipanel Display Setting #23
New member here and new owner of a L4060. Had this same problem so I thought I'd join to 1) say thanks for the info! and 2) say that my initial setting was 1766. I changed it to the recommendation you guys had so hope that's the one for and L4060 with R4 tires. Looking forward to sharing and gaining more info as my ownership continues! Traded a '99 New Holland TC29D so this new one feels like a giant in comparison.
/ Intellipanel Display Setting #24
I played around with it some more this afternoon, and it's definitely not in any of the normal menus or settings.
The reason why it's not documented anywhere in the user manual is because the change needs to be done from the diagnostics / service menu. To access the service manual, you need hold the Display Mode button down and then turn the tractor on (but you don't need to start it though) while holding the button in. Once the service menu appears, scroll to option "J" and select it (by holding down the Display Mode button); from there you can either select kph or mph (once selected - hold button and it "OK" will appear at the bottom of the screen.)
I had to do a bit of thinking to figure this out! :)
This was very helpful. Thanks for getting me to the service display.
What are the other selections that are available in the service menu? Maybe one where I can set my clock??? :licking:
/ Intellipanel Display Setting #26
Old thread I know.......but for anyone's benefit, the number for the l3560 (smaller) R4 tires is 2404. This is located under the B Selection.
/ Intellipanel Display Setting #27
I know this is an old thread, but maybe someone can educate me. I have no idea what R4 means when talking about tires. I know what industrial, turf, and ag tires are. I just bought a new L4060 and I had my dealer take the industrial tires off and put on ag tires. How can I find the ratio for ag tires? I toggled through the display for 20 minutes tonight and could not find any way to change from metric to SAE. I will go back out to the barn later and try to access the service menu mentioned in this thread.
Edit to add: I found the service menu, and mine had the KPH/MPH setting under the J menu just like you said. But I still have no idea what tire ratio to use.
/ Intellipanel Display Setting #28
R1 = Ag
R3 = Turf
R4 = Industrial
/ Intellipanel Display Setting #29
Lynyrd, The instructions and codes you are looking for are part of the assembly instructions the dealer gets, they normally just throw these away when finished. If you send me a message with your email address, I will email you the instructions needed. Philip.
/ Intellipanel Display Setting #30
PM Sent
/ Intellipanel Display Setting #31
Eric -- I have an L4060 with the R4 industrial tires. Can you please confirm what the correct 4 digit code is for the coefficient? Thank you very much fro your work on this.
/ Intellipanel Display Setting #32
I have an L6060 with R4 tires that is displaying Kilometers per hour and needs to be changed to MPH. Can anyone help me out and confirm the correct letter on the service menu to change it to mph, and the letter for the coefficient of speed and the setting for R4 tires on an L6060?
Thanks
/ Intellipanel Display Setting #33
Thanks
Did you read post #12 and #18? They seem to have the information you seek.
/ Intellipanel Display Setting #36
Good morning!
I have the L3560 with Titan Turfs. Would you happen to know the code for the Turfs?
Thanks!
Brent
/ Intellipanel Display Setting #37
Thanks
/ Intellipanel Display Setting #38
This is excellent, thanks for posting the full list. Can you confirm this is the most up to date? I have 14.9-26 r1 and my B setting was 1919 which isn't even in the list.
/ Intellipanel Display Setting #40
This is cool info i just did my 2021 L4060 it was not at the right setting it was just 1 minute to fix ,Thanks for this info .Am sure lot of tractor are not at the right setting you think the dealer can make that change before the tractor leave the dealership .
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
Tennant M30 (A64127)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
