DK 40 ; how many GPH ?
/ DK 40 ; how many GPH ? #1
drjay9051
Gold Member
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
Recently got a DK40 HST. Previously had a CK 25 which sipped fuel . The DK seems to burn a lot more per hour. Does the fourth cylinder make that big a difference. I have no specifics other than I have been running it at about 2100-2300 RPM for extensive box blade work. Seems like it hits E pretty quickly. Not in a matter of minutes but seems quicker than with the CK. There are no fuel leaks as far as I can tell. What is a typical gallons per hour fuel burn at the above RPM.
Oh yes: This new beast is a dream.
Thanks.
/ DK 40 ; how many GPH ? #2
Your GPH will improve over time. Just enjoy it in the meantime, seriously, they usually improve with use. My understanding is the fuel gauges on these are not totally accurate; meaning as the fuel gets lower the gauge MAY not show what actual amount is left. Try noting how much fuel you add when gauge shows empty. It may not reflect the tank capacity. You could also try lowering your RPMs slightly, depending on need, while BBing.
/ DK 40 ; how many GPH ? #3
FWIW, the ag. engineering literature estimates of average diesel fuel consumption per rated PTO-hp range from 0.044 to 0.048 gallons per hour under average operating RPMs.
Steve
/ DK 40 ; how many GPH ? #4
Steve
Make that gal/hr/hp. Diesel fuel consumption depends mainly on how much HP the engine is producing.
/ DK 40 ; how many GPH ? #6
I had the same thoughts and did exactly what you did, started a thread about it. In fact, our threads seem to be almost identical in the first post. (http://www.tractorbynet.com/forums/kioti-owning-operating/257618-beast-pig.html) The tank is apparently shaped like a cone but reads as if it were a cylinder. If you make sure you fill it right up, you'll find it's actually pretty light on fuel, not as light as a CK, but a lot better than you're thinking now.
/ DK 40 ; how many GPH ? #7
I figured I was using about a gal/hour doing heavy work like box blading. Also there seems to be alot of reserve near empty but I try not to run it that low.
/ DK 40 ; how many GPH ? #8
My working RPM burns about 1 gallon per hr on my DK40HST. Yes the fuel tank sender read empty when there is still almost 5 gallons in the tank....that's a heck of a "reserve":laughing:
I think that is the issue. It seems to hit empty but likely lots more fuel in the tank. Just a bit disconcerting when you fill the tank and a couple of hours later your needle is hovering at E. I just may run it at E and see how much work time I have left. i'd think no harm just bleed off the air if needed.
Thanks everyone
/ DK 40 ; how many GPH ? #10
My DK45S still has in excess of 5 gal in the tank when the gauge reads empty. I use very little fuel unless I'm running a PTO load (like a mower), which consumes HP at high RPM. Just moving around and running the loader seems to use very little fuel. But my gear-transmission tractor runs at pretty low RPM for most loader work (vs high RPM with a mower). I suspect the HST version will use considerably more fuel because of the higher required engine RPM, At higher RPM, all kinds of parasitic losses (from the cooling fan to viscous forces in the tranny) will consume engine power in the HST models.
/ DK 40 ; how many GPH ? #11
Parasitic losses?:confused2: Not MY DK-40 HST!:thumbdown: It must be YOUR extra 5HP that you're carrying around that's sucking up most of your extra fuel!:laughing: 'Viscous forces', OK Darth, turn off the lighsaver and come back to earth.:rolleyes:
Seriously, though, I don't think one looses a lot of fuel to differences between manual and HST trannies; butI'm sure there are those who would argue otherwise.
It would be nice if Kioti could use a guage that reflected actual use, with an accurate reserve, with a light, just like an actual fuel gauge found on everything else on earth; (well except my Scag- NO gauge at all!).:duh: Wildcat:thumbdown::confused3:
/ DK 40 ; how many GPH ? #12
Seriously, though, I don't think one looses a lot of fuel to differences between manual and HST trannies; but I'm sure there are those who would argue otherwise. If so, can we examine actual unbiased data, gathered by independent analysis?
It would be nice if Kioti could use a guage that reflected actual use, with an accurate reserve, with a light, just like an actual fuel gauge found on everything else on earth; (well except my Scag Wildcat - NO gauge at all!:duh:). :thumbdown::confused3:
/ DK 40 ; how many GPH ? #13
I was wondering about that same thing, Consumption difference between HST vs Gear. Only time I see higher RPM's is brush hogging and backhoe work, Other than that it's at idle or a hair above.
But then again I am partial to manual transmissions and do enjoy the fuel economy in all my vehicles.
/ DK 40 ; how many GPH ? #14
My new 1025 uses about twice the fuel as my 4010 did, and the 1025 has only 5 more hp over the 4010's 18.5. A friend of mine has a larger Kubota. He says the new one is using more fuel than the old one. Think it's something to do with the tier 3 emissions controls. Normally, emission controls reduce fuel consumption because they have to be more efficient to get emissions down. Seems not to be the case with these tier 3 machines.
Ralph
/ DK 40 ; how many GPH ? #15
Have 5 gallons ready. Start with a full tank and run it to "empty"(should be between 4 & 5 hrs). Stop and dump in the 5 gal...I bet thats all it will take which means you still had 5-6 gallons in there.
/ DK 40 ; how many GPH ? #16
Does the HST use more fuel, yep sure does!! How much more, I would bet about 2 quarts of fuel per 10 gallons. Can I live with that? OH HECK YA. If it was 20% more I would be good with it. Ran a gear tractor yesterday, NO THANK YOU. CJ
/ DK 40 ; how many GPH ? #17
I don't think my fuel gauge is quite that bad. Maybe a couple of gallons left in reserve with the needle at E. I don't mind though as I'd rather not run out of fuel while a mile away from my fuel supply.
On gallons/hr, I don't usually run (actually almost never run) as high as rated PTO speed but with 1800rpm for backhoe work or 2200 for most mowing, I use less than 1 gal/hr. Maybe something like 0.75g/hr average. I got about 0.5gal/hr with my CK20 but that stands to reason. And, when I think about the amount of work that gets done with a tractor hour compared to what my hands and back can accomplish, I wouldn't care if the DK drank 5 gallons/hr, I'd just refuel more often!:laughing:
/ DK 40 ; how many GPH ? #18
My thoughts exactly. When I think of how many tons of rocks I can move with a gallon of diesel it is unreal! Tractors cost a lot of money, but the amount of work they will do for the amount of fuel they use is a bargain!
James K0UA
I appreciate all the replies.
Yesterday I took out the DK40 and at start it was right on E. An hour later needle below E. 1 1/2 hours after that finished doing the drive and other stuff. So after 21/2 hours on E still had fuel. Must be the gauge.
Thanks again.
/ DK 40 ; how many GPH ? #20
Thanks again.
If I were you I would just fill it up now and calculate how much fuel you added (can always weigh the remainder of the last 5 gallon can to calculate what's left). It is a PITA to run out and have to bleed air from the system in the field.
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
