Intellipanel Display Setting
/ Intellipanel Display Setting #1
CortezEd
Member
Cortez, FL
Kubota L6060
I have a new Kubota L6060. The dash (Intellipanel) is displaying travel speed in units of km/h (kilometers per hour). How do I change this to mph (miles per hour)? My head doesn't work in metric mode...
Thanks, Ed
/ Intellipanel Display Setting #2
On my L5740 I just push the display button and it cycles from km to miles.
/ Intellipanel Display Setting #3
I can only tell you to look at your OP manual. Yours will explain, in detail, how to change any & all values on the display. Mine came with everything displayed in metric terms - so I got a real lesson in changing the values.
/ Intellipanel Display Setting #4
Yeah, it is hard to generalize as my L5740 is a lot different than our M8540 and I believe a bit different than the new L60.
/ Intellipanel Display Setting #5
Push the button ... you know you want to ... go ahead ... do it!
/ Intellipanel Display Setting #6
That is how mine works to. 1st to come up is mph, next to come up is kph. Just keep pushing display mode switch to cycle thru display options. Did you get a second small manual just for your intellipanel? I did. Philip.
Thanks everyone. I have read the operator's manual numerous times trying to find information - but couldn't find a thing about switching from km/h to m/h. I did find a YouTube video about the Kubota Intellipanel and saw where the person cycled through the various displays by pressing the mode button and the travel speed changed to mph. I'll try it out and expect that will be the solution...
I also wonder why the PTO speed units show as n/min instead of RPM. Apparently they both are the same? 540 n/min = 540 RPM ???
Something to do with Fig Newtons I guess? :licking:
/ Intellipanel Display Setting #8
They just mean Number/min as in number of revolutions. Must be the Japanese version of rpms.
/ Intellipanel Display Setting #9
Did anyone figure out how to change this? I'm in the same situation as the OP and there's literally nothing in the manual(s) that explains how to change this. Thanks!
/ Intellipanel Display Setting #10
Push the button. Keep pushing the button until it displays the information you want.
/ Intellipanel Display Setting #11
When you say "push the button" - do you mean to hold it down? I know you can hold it down to change things like stall guard and auto-ds, auto-rpm, etc., but I couldn't find anything in the menu where you could select mph/kph (I'm sure I'm being clueless, but it wasn't obvious to me where this setting resides in the menu.)
Here's a video of the different things you can select - and when you hold the button down it will let you change that particular setting (based on the context of what you're currently looking at):
Kubota Grand L60 Series Dot Matrix Digital Screen - YouTube
/ Intellipanel Display Setting #12
I played around with it some more this afternoon, and it's definitely not in any of the normal menus or settings.
The reason why it's not documented anywhere in the user manual is because the change needs to be done from the diagnostics / service menu. To access the service manual, you need hold the Display Mode button down and then turn the tractor on (but you don't need to start it though) while holding the button in. Once the service menu appears, scroll to option "J" and select it (by holding down the Display Mode button); from there you can either select kph or mph (once selected - hold button and it "OK" will appear at the bottom of the screen.)
I had to do a bit of thinking to figure this out! :)
/ Intellipanel Display Setting #13
I was somewhat surprised to get a call from Kubota this morning. Basically, they said I was half right on the answer and were somewhat surprised to see I found the service menu on my own (I guess it wasn't intended to be easily found! :) )
Anyway, they said the coefficient of speed also needs to be set to get an accurate account of mph. The factory default coefficient is set for R1 tires and needs to be changed depending on the tire installed. Unfortunately, they didn't have the correct number for the R4 tires, so I'm going to check with my local dealer to see if they could find this information in the service manual. I just wanted to pass this along in case anyone else runs into the same issue.
The speed coefficient is the "B" option in the same menu. It's a 4-digit number you need to set it to.
/ Intellipanel Display Setting #14
Sorry about my response - now that I see your photos I understand that our Intelipanels are very different. I guess the 60 series really added a lot to what it can do. On the Lxx40 series you push the button 4 times to scroll thru 4 different displays and that's about all it will do. 1st is total hours, 2nd is mi/hr, 3rd is km/hr and 4th is PTO rev/min.
/ Intellipanel Display Setting #15
No problem and thanks for responding!
/ Intellipanel Display Setting #16
I am curious to know why they don't put that information in the manual for the Grand L60 series. My new M135GX has the things you are talking about like setting tire size, Japanese or American units (I don't think they say metric or English), and some others. My dealer really sucks so I don't think I would be able to get any info like that if it wasn't in the book.
/ Intellipanel Display Setting #17
Keep us posted on what you find out so I can set mine up correctly.
Stu
/ Intellipanel Display Setting #18
I was told 2709 for the larger set of R4's on the L60 Series (I'm guessing for the L3560 the number would be different.) You might want to verify it with your local dealer (they can just look it up in their service manual.)
If anyone knows the numbers for the other tire sizes, it would probably be good if you could reply to the thread with this information to use as a reference in the event someone wants to do a tire swap or verify the number was properly set.
/ Intellipanel Display Setting #19
Thanks! Looks like 2709 will work for my 4060.
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2011 FORD F-150 (A65643)
2011 FORD F-150...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
