DK Tool Boxes and Chain Canisters
/ DK Tool Boxes and Chain Canisters #1
gunmonkeyintl
NC
DK40SE HST
I've been out of town more than home lately, but finally got some more seat time working on my road project, and finished my chain and tool storage project this weekend.
I borrowed the chain can idea from another post on the forum, but expanded on it. Like the other poster, I replaced my plexi kick panels with plywood plates and yolks to hold a PVC pipe, but I made the pipe into removeable canisters. I bent some 5/16" rod into handles, and cut the caps so that they lock into place on the handles. The canisters are held in place with a ratchet sinch, so I can lift off the canister and take the chain to the log without having to wrestle it like a python. I found on my first trip out with them that the mounted canisters also provide a convenient place to hang my helmet and chaps (later pic).
I also mounted a couple tool boxes. I started with a couple holes on the sides of the fenders, below the out-board ROPS bolts:
I fitted rubber grommets to keep vibration from wearing the paint at the mounting site:
I welded up a couple baskets that bolt to the ROPS mount and fenders and hold the deep plastic ammo boxes. My first time out with them, I some miscellaneous tools and my gloves in one, and several bottles of water in the other.
Mounted, the boxes are just narrower than the exposed part of the tire, so I don't have to worry about snagging them on anything that wouldn't be scraping my tire, and I can reach them easily from the seat.
Being removeable has already proven handy, since I don't have to root around for tools in a box up high on the tractor. When I needed to do attach a clevis to my drawbar, I just took the tool box down behind the tractor with me. Too, when it gets hot again, I can throw some ice in with my water and dump it out when I'm done.
It's still not as much on-board storage as I'd like, but it is a step in the right direction.
/ DK Tool Boxes and Chain Canisters #2
How did you post all your pics upside down? Now my Wife has to hold the Lap Top so I can scroll through them
/ DK Tool Boxes and Chain Canisters #3
Stand on your head Murph!:laughing:
Sorry about that. I posted from my Iphone, which always does weird things with pictures.
I appreciate the dedication it took to look at them, but I went ahead and edited the post to correct the orientation.
/ DK Tool Boxes and Chain Canisters #5
I would like to see your chain saw mount.
/ DK Tool Boxes and Chain Canisters #6
You do nice work!
/ DK Tool Boxes and Chain Canisters #7
To the OP: What is on the seatback on your DK? Why didn't your hoe come with bigfoot pads installed on the stabilizer feet? Is that not a stock item on the Kioti hoes? If not I strongly suggest looking into them- they came with mine and provide extraordinary gripping of encountered ground surfaces.
Nice work on the storage, and could you try to upright the pics for Murph, please, and me too, and others? Thanks,:thumbsup:
CM
/ DK Tool Boxes and Chain Canisters #8
Some real nice additions gunmonkey.
/ DK Tool Boxes and Chain Canisters #9
I would like to see a better way to mount a Saw.
CM
On the seat back? There is a spring-loaded pocket on the back that the dealer said is for the manual. I don't keep anything in it, though.
We never discussed any optional stabilizer feet, and the ones that came on mine are exactly as pictured in the parts section of my manual. I'm not sure what grips on my stabilizer feet would do. When I really get on it, the hoe is plenty strong enough to toss the 7500# machine around. Seems like larger feet or teeth wouldn't do much to keep it planted. I'm open to anything, though.
/ DK Tool Boxes and Chain Canisters #11
Get the Big Foot pads as they stop you from getting tossed so much.
I currently throw it in the BH bucket or loader along with a shovel, mattock, sledge, and crate of dynamite.
It's working for now, but is a little annoying having to unload it and reload it whe I need to use the bucket.
There is a saw mount that was recently posted, bolted on the rear of the ROPS. It seemed workable, but potentially inconvenient to get to.
I'll come up with something eventually. I'm going to work on the long-handle tool and storage first, though. I'm considering switching to C4 which will save considerable space over the dynamite.
/ DK Tool Boxes and Chain Canisters #14
My Kolpin brand mounted chainsaw holder is easy to remove or install most any size chainsaw. Stand facing the middle of the tractor from the right side, near the rear tire. Reach over with left hand and undo the contained bolt's knob while holding the saw in place with the right hand. Move saw off holder and GO!
BTW, I make sure things I recommend are tested and approved by my own private testing firm with select testers: ME!
Trust me Murph and GMIntl., this holder WORKS!
Like the Big Foot pads, once you go there you are not going back.
GMI, I guarantee that the big foot pads will do a WAY better job than having nothing on the bottom of the pads. The holes are already drilled in the pads on the stabilizers.
Where are you getting 7500#'s # from? Machine with loader is around 4000# IIRC, and the hoe is around 1K#s.
Pics and 2006 era prices in this thread:
http://www.tractorbynet.com/forums/.../77410-backhoe-stabilizer-pads-installed.html
Thanks. Look easy enough to build. May make some to bolt on some day.
The tractor is 3900#, the loader is 1300#, the BH is 1100#- that's 6300# before the tire load. The dealer said "about 7500#" when I asked him.
/ DK Tool Boxes and Chain Canisters #16
I guess that's pretty close- forgot about loaded tires, and thought the 4K was tractor and loader, been a while since I added it all up. That's a LOT of weight!
/ DK Tool Boxes and Chain Canisters #17
For someone who can weld, it would be easy to make BigFeet with some 3x3 heavy angle iron. Big Feet do work in turf or soil but the are kinda pricy.
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2016 Freightliner 108SD T/A Rolloff Truck (A64194)
2016 Freightliner...
2022 EZ-GO ELITE...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
