Weight on axles question.
/ Weight on axles question. #1
Orange 08
NW California
BX24D
On a tandem axle trailer with leaf springs does the weight equalize between the front and back axles so the front axles don't carry more weight? Do axles with torsion suspension also have a way to equalize the weight?
/ Weight on axles question. #2
In theory the leaf spring suspensions equalize out. From my weighing well over 50 trailers the usually are within 10% of each other.
Torsion axles do not and because of this I see 10 to 1 blown tires. I also see 3 times as many bent axles and spindles. I have weighed a trailer that had torsions and constantly blew front tires. It had 70% of the weight on the front and 30% on the rear. Needless to say I am not a fan.
Chris
/ Weight on axles question. #3
Diamondpilot is correct that leaf spring suspension with a walking beam is for the most part "Load sharing" The torq flex axles are not and can't be made to be load sharing that I know of. I have seen very few tandem axle trailers with the torq flex axles and would not own one. Torq flex axles work very well on single axle trailers. My .02 cents
Steve
I was looking a tilt bed trailers. One large, very long, 14,000# bumper pull one had the axles set back very far back. Dealer said it would clear the loaded car door better. Trailer had torsion axles. That got me thinking about axle weights. Looking at more tilt bed trailers they all had torsion axles. Are torsion axles used on tilt bed trailers to get a lower deck height? Any other reason?
/ Weight on axles question. #5
Mike, you could be right about the lower deck height on a tilt bed trailer. With leaf spring sprung suspensions you are limited to only so much drop on the axle itself, usually around 4" to 6" drop. With the torq flex axle a lower deck can be had because you dont have the extra height of the spring , saddles and the walking beam. Dexter Axle - Trailer Axles and Running Gear Components - Home
Can you post a link to the trailer mfg and/or a few pictures of the trailer that you are looking at? A really long bumper pull trailer with the axles set way back? Thats a bunch of weight on on the receiver, better off to have a 5th wheel set up if the axles are that far back. My .02 cents
Steve
/ Weight on axles question. #6
just having leaf springs on it does not mean it has equalizers, on the unit, equalizers are the middle part that pivots and the springs are attached to.
I have seen trailers built with out of the equalizer. (why I do not know)
Steve
I would really rather not mention brands in case I am all wrong. I'm trying to educate myself here. If I do go by there again maybe I can take some measurements. I am sure, as you mentioned, with this size and configuration a 5th wheel or goose neck would be better handling.
/ Weight on axles question. #8
Orange08, You never mentioned what type of vehicle that you are going to use for pulling a trailer or what you want to haul. I only asked about the brand name to see if I could find one on the internet to get a better idea on what you are looking at.
Steve
Towing truck is a F350 diesel.
I was thinking of a tilt trailer to load a fairly low BMW. Probably only need a 10,000# trailer for that. I did need to tow the Ford once to get it fixed but that would be over 10.000# if I ever had to do it again. That time I had to get a friend who had a trailer for his back hoe to move it. I suppose for as many times as I would need to do that I could call a wrecker.
Looking at the long trailer the dealer had got me thinking about axle weights.
/ Weight on axles question. #10
Not sure what your budget is, but check out Imperial Trailer, they are pricey I hear. I had one( about the same as the one in the link), but had bought it used. It was a nice trailer. If you get either their lowboy or or split deck lowboy, they have equalized leafs... the car haulers have torsion axles it seems.
Imperial Trailer contact form for custom built trailers
/ Weight on axles question. #11
Orang08. I'm sure that your F-350 could handle the long trailer with the axles set way back. The concerns that I would have would be the receiver weight rating (bumper pull) and the torq flex axles set near the end of the trailer. The front axle would support a bit more weight then the rear axle. If all you need to do is haul a beamer around once in a while then Im sure you would be OK. A full size backhoe on the trailer? wellll, not so much. Trying to find a trailer that low riding cars load without draging it's bottom on the trailer deck is one thing. Trying to get out of the car after its loaded is another. Yep, either bash the door on the trailer fender and squeeze out of the car, or climb out through the window (NASCAR style) and try to figure out how to close the window without opening the door. I have seen some car trailers with removable fenders to gain a little more clearance but not sure how much more room that would give you.
Steve
/ Weight on axles question. #12
Just a fyi a 4x4 backhoe is in the 15k-20k range and I would not tackle that with a tag unless it was a pintle hitch.
