Price Check Yanmar 240 Value?
/ Yanmar 240 Value? #1
Gale Hawkins
Super Star Member
Murray, KY
1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Is a tractor as per the text below even worth $1200 if it would start and run?
Purchased as "non-running tractor". Got it started and smoked too much. Installed rings
and inserts. Now it won't start. My loss you gain. It is 25 hp. 2-cylinder diesel. 3-point,
PTO all work, Good tires.
/ Yanmar 240 Value? #2
I would buy it. I've owned one for ten years and like this model.
But in this particular case, budget another few hundred $ at most to unscrew whatever he screwed up when he put it back together. Still a bargain, and likely it will need nothing more than some hours of analyzing what isn't right.
If you're lucky all it needs is bleeding the air out of the fuel line. Or maybe he didn't understand how to adjust the valves. I doubt its an expensive problem, these things are too simple to need much.
Running? I would say well over $2,000 depending on location. Over $3,000 out here. Search for 'YM2000' for comparables, those come up for sale more frequently and they are simply the Japan-market version of the same tractor.
/ Yanmar 240 Value? #3
I'm not a tractor value assessor, although when I look at something I'll tend to itemize things of value, Like looking at the wheels/tires of this tractor could be worth over 1/2 the price, or the hood/sheet metal, radiator, etc,etc, if at worst case I could still recoup my $$$ ,
I'd say even if having to invest another 1,000 in it, it would be worth 2-3k just as California stated,
/ Yanmar 240 Value? #4
I would say that its worth $1200, even if it has to be parted out. You could easily get $300 for the rear tires, the rear trans section could easily bring $500 to someone who needs it, radiator $50, sheetmetal another $200 maybe.
Unless tehre is a hole in the block or you cant turn the crank by hand with a big socket i would say go for it.
/ Yanmar 240 Value?
Thanks.
I know of no one that owns one in this part of the country. On hilly ground do they tend to be semi stable? Will they do as much work as a red belly Ford? what size finish rear mower will the tractor handle okay? What would be the weight range of that naked tractor?
/ Yanmar 240 Value? #6
In terms of capability, think of a 7/8 scale 8N. The engine is 24 hp vs the 8N's 27 hp. 1800 lbs vs 2700 (?) for the 8N, plus used 8N's are more likely to come with additional ballast. Dealers say run a 4 ft rotary mower on a YM240.
In in my experience a 4 ft rotary mower can work it hard in waist-high wet orchard grass if half the mowing is uphill as in my case. But I think putting an 8N's 5 ft mower on the 240 will get more acreage done per day than a 4 ft and won't strain it if you take a partial cut in the heaviest material. YM240's compound low gears are a definite advantage over 8N especially for a rototiller, or for creeping up to a pallet using front forks etc. And it can maneuver better in tight spaces. They are narrow, I added a ROPS and water in the tires before I felt safe on side slopes.
I think the only point where an 8N is clearly better is discing - its added weight for traction and its 3-point lift capacity are greater.
The advantage of a YM240 is that its bulletproof. No tuneup, nothing to tinker with or maintain, and it will run like new for years. There's nothing breakable; I made every sort of idiot-new-owner mistake and never broke or wore out anything in ten years. You seldom see posts here about repairs beyond keeping the cooling system maintained etc.
Don't know if you are aware - Yanmar entered the US market in the 1970's parallel to Kubota and YM240 was a model they sold here for several years through authorized dealers. Then later Yanmar contracted to build Deere's compacts and ended US sales until their recent re-entry. Yanmar-USA still supports this model with legitimate factory parts. I like to think this specific Yanmar was what spooked Deere into contracting Yanmar to build for them, instead of designing their own compacts in-house, they recognized they couldn't exceed its quality.
Now today a huge number of YM2000, the Japan-market version, have been brought over and a healthy replica parts market exists here selling NAPA quality replacements. So YM240 has both factory and 3rd-party support.
I see a MF265 in your profile. Think of this as a smaller sized version of it. I'm certain you will love the YM240 as soon as you get the prior owner's confusion sorted out.
/ Yanmar 240 Value?
Thanks for the info. I am as green as grass about them but I am learning they are good machines even painted lime green.
Yes the 265 MF is a solid tractor with not even 12v required to keep running after started. It is stable but way too heavy to mow extended lawns if it has rained recently.
We are going to look a portable horse barn today for the minis so they are not standing out in freezing rain six weeks from now. Saw the 240 in the process of looking for fast horse housing. I may get to check out the 240 tomorrow if it is still for sale. Expect someone will part it out based on what is being posted. Never had or wanted a red belly but would like a small light tractor. I could get it on my 3500 single axle tilt trailer I expect because it is rated to carry about 2400 pound loads.
/ Yanmar 240 Value? #8
... even painted lime green.
Yes the 265 MF is a solid tractor with not even 12v required to keep running after started...
The weird green was a marketing mistake. It must have meant hip, modern, like a green polyester leisure suit, when they started using it. Thankfully they came to their senses for the later models.
No 12v needed on these if you want to carry a single battery around to start each of your fleet in the morning. The manual discusses this, says leave the key off if no battery. The marine version of this engine (2Q-something) has a hand crank option. And no fuel shutoff solenoid or fuel pump between tank and injector pump. The starter, lights, horn are the only electric items. Stuff that isn't present can't cause problems.
I brought mine home 100 miles on a 4k rated U-haul rental behind an old Trooper rated to tow 2k. It hasn't been off the property since, no need. I expect your single-axle trailer would be fine if driven cautiously.
This model sounds perfect for the use you describe.
/ Yanmar 240 Value?
Did call the guy. He as sold about 20 yanmars since retiring 20 years ago along with many other small tractors more or less as a hobby. He said this is the only Yanmar he gave up on getting to run and he did not want to sell it to me until he found out it would be a project for me and the kids. He does not junk tractors but stated it would junk out for more. If I like it and have the money after a barn he said he will put it in my driveway. He thinks $300 will get it running. Fuel is not getting to injector pump per him. His younger partner did the rings and inserts but never got it to run again and at 80 the seller said he knew when to fold on a business deal where selling at a profit is never going to happen. He states the tractor starter turns the engine just fine and he thinks the tractor will be fine when someone gets fuel to the injector pump.
From what you stated maybe a gravity flow test option could be rigged up to get it to running since the marine version does not use a lift pump I took from your last post.
/ Yanmar 240 Value? #10
Guess I was unclear. No lift pump on YM240. And crank start available for marine version.
If he has repaired/sold 20 Yanmars and can't get this one running that would give me pause. But ... if he really means no fuel arrives at the inlet to the injector pump, and he can't fix that, then he's going senile or something. It's a straight gravity path from fuel tank > fuel filter (external, not part of the tank) > and down to the injector pump inlet banjo fitting. The bleeding procedure is: open each in turn until pure fuel flows. first the one on top of the fuel filter nearest the tank. Then the one on the output side of the filter. Then the bleeder down on the injector pump inlet banjo. You could do this while he watches - just take a large Phillips screwdriver and/or a couple of small wrenches - 10mm? If nothing makes it down to the injector pump, investigate. A fourth grader could do it.
I would be more cautious if he is afraid to sell it as is, but I can't believe there could be an expensive problem if it cranks over and seems to have compression. Worst case might be an injector pump. $350 from Hoye. I don't know why he would touch that doing a ring job so it is unlikely he damaged it.
/ Yanmar 240 Value?
He said after buying it as a non runner the guy that helps him now that he is able to do less due to being 80 got it to running but it smoked them out. He did not want to sell it to someone looking for their only tractor and needing a tractor.
Our two kids want to go to MX to build houses for families again like last year and the flight and fee for the week is $1200 to help a family get a new home. They are built on a slab that is poured ahead of time and seem to be more like our 16x20' finished out portable buildings. We have enough projects under way at this time so helping bring a family tears of joy New Years week will be money better spent. Most of the fee goes to buying materials used in the homes they build.
I agree if they have sold 20 Yanmar's (has three running ones for sell current but the one with the FEL he said he uses too much to sell) and his good mechanic can not figure out how to make it run after it actually having it running before the ring job sounds strange and he said so himself.
If I were retired I would really consider getting in to the junking of tractor business in a small way. Not sure I could cope with the shipping part. :)
We bought the 10'x20' portable Run In horse shed for the mini hours tonight that is a 10x12' open run and in one end is a nice 8'x10' tack/feed room. So tomorrow we will try to get it home so that will be an 180 mile round trip on the F700 with the 16' flat dump. He has a JD 250 skid steer to help get it lifted enough for me to dump some and start backing under it so we can work it on.
/ Yanmar 240 Value? #12
Heck send the kids to Mexico, that sounds like a worthwhile project and better use of the money. :thumbsup:
Especially when compared to going crazy with frustration trying to outthink two experienced mechanics!
I've had good luck 80% of the time buying something cheap because the prior owner didn't know how to fix simple stuff. But I've wasted time on ones I didn't recognize were impossible, too. This YM240 is beginning to sound like one of those. Hopefully you'll find another some day.
My worst example was an old $100 Mercedes Benz diesel. Turned out the reason the engine clattered was the OHC timing chain - same as bicycle chain, tempered steel - had disintegrated some rollers and then circulated fragments through the engine for months. Everything inside was scoured like coarse sandpaper hit it. I sold the MB intact, for parts, for the same $100 I paid for it. It still drove but the clatter was frightening.
/ Yanmar 240 Value? #13
Yea "getting" fuel to pump is not hard. But if pump is out of time or has stuck plungers the engine will not fire or run right.
You can see if the fuel is at the injector by cracking the lines but I'm sure he knows this. It does sound like a project but I bet its still something simple.
If he knows he can't fix it and sell for a profit I think you are in place to offer less and get a deal, after all he can't fix it and messes with these!! I'd let him know you may down $2+k and end up with a parts tractor.
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
2022 EZ-GO ELITE...
(2) 18x38 Rims (A65640)
(2) 18x38 Rims...
Cattle Feeder (A65640)
