Oil & Fuel NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #11
I have a question,say you have some hydro or gear failures during your warrenty period after you use TSC or NAPA fluids other than the Kioti branded fluids will Kioti stand behind the failure since you did not use there branded fluid?Just curious?
To my knowledge, Kioti does not have branded oil. They reference major brands in the manual.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #13
No, they cannot void the warranty as long as you use oil that meets the specs...
Magnuson
Warrantors cannot require that only branded parts be used with the product in order to retain the warranty.[7] This is commonly referred to as the "tie-in sales" provisions,[8] and is frequently mentioned in the context of third-party computer parts, such as memory and hard drives.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #14
What brand name does the Kioti dealers carry?Has anyone checked?
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #15
The local kioti dealer near me uses Cub Cadet UTF, Which is not in the manuals BTW.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #16
My shop manual states,Daedong(TF65),Exxon(mobilfluid 423or424),Shell(donex-td/td plus)BP(tractran UTH)
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #17
Mine as well coobie, I still haven't found any of those fluids locally, So what do ya do?
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #18
Shell Donax TD is now called Shell Spirax S4 TXM. I found and bought two 5-gal containers at a local Walmart but never saw any more there after that. By the way, there are MANY Shell Spirax products and the S4TXM is the important part (T=tractor, X=multi vehicle/multi OEM, and M=low maintenance).
I have been to several dealers, and each uses different or multiple kinds of oil. You my notice in the chart from Kioti at the start of this thread, it says possible fluid.
I just emailed Kioti for a direct answer on the oil and warranty. I will let you know answer the ASAP. :)
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
TANK MANIFOLD (A55745)
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
Groundhog RH14G Vibratory Articulated Tandem Smooth Drum Roller (A55851)
Groundhog RH14G...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55314)
2023 New Holland...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
