Oil & Fuel NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #41
No need to get perturbed there pardoner, and yes I read "locally". :rolleyes: Just pointing out you don't have to settle for NAPA if you don't want to. NAPA is not a end all be all, nor is TSC, although Tractor Supply Company versus National Automotive Parts Association, what's in a name anyways? :D
And Waltrip got booted.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #42
TSC carries Mobil 424 here.
TSC Traveller Universal Tractor Trans/Hydraulic Fluid
Traveller Premium Universal Tractor Trans/Hydraulic Fluid is a specially formulated, premium multigrade (SAE 10W-20) fluid
Additive Type - Premium
Flash Point - 435 deg. F
ISO Viscosity Grade - Multi-Viscosity
Pour Point - -44 deg. F
Size - 5 gal.
Viscosity (SUS @ 100 F) - 400
Brand - Traveller
Mirrors the NAPA
Flash Point - is same as boiling point
I am man enough to say I changed my mind. I went by NAPA the other day to get hydraulic oil for my tractor. The NAPA dealer said he was out. He did not offer to order any, so I moved on. They have went down hill over the last 2 years. Parts and product setting in the floor. Just real messy. Anyway, I stopped by TSC and picked up Traveller's hydraulic fluid. I notices on the side it said, 10W30. NAPA premium said 10W20. Both meet Kioit's requirement, but I could not get over how much stronger my hydraulic system is! Before, it would just barely pick up the front end at operational temps and high RPMs. Now it does it without any problems at operational temps and at low RPMs. The system just works better.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #44
Only thing about Wally World, it seems Wally changes out or drops things quite regularly.
It is back in Wally World at Harrison now.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #45
My CK35 just hit 50 hours and I did rotella 5w-40 T6 for engine oil, 80w90 gear oi in the front axel. The front axel when I drained it looked to be hydraulic fluid and not gear oil. For the trans and hydrailic I just purchased TSC Traveler premium fluid for 27.99 per 5 gallon pail. It is on sale right now till 11/22 in my area. Here are a pics of the labels. They seem to cover all the bases needed for Kioti.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #47
I have a question,say you have some hydro or gear failures during your warrenty period after you use TSC or NAPA fluids other than the Kioti branded fluids will Kioti stand behind the failure since you did not use there branded fluid?Just curious?
Coobie, I use that NAPA product in my BX25. I work it hard and change fluid every 400 hrs now have 1500 hrs on it. I had the same question on warranty on my BX as they promote their branded SUDT2; discussed with the service manager at my dealer and he stated that not using their branded oil does not void the warranty. Huge difference in price. I also use NAPA filters.
Ron
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A56138)
2007 INTERNATIONAL...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52707)
2017 FECON RTF140...
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
