Questions about a tank for my new Mig Welder...
/ Questions about a tank for my new Mig Welder... #21
Doc, I have a bush hog that has two pretty serious fractures...I hit a pretty big log and it cracked the deck on top on each side about 1/8 " wide by 6" long splits on each side at the front ...top of the bush hog deck...it is about 3/8 " thick...so I thought for this project I may need the shielding gas for deeper penetration at least that is what I have seen on a few You Tube videos....other than that ...I agree...I would rather not mess with gas but I am thinking....never know what repair may be needed and if the penetration is greater with gas...why not.....just as long as I don't blow myself up....:confused3:
#1 3/8" is right at the top limit for what can be done with a 110v MIG welder. Some would argue it is over the top.
#2 Unless you can bring that mower into a garage where you are set up with CO2, I would think that fluxcore would be just as good. I don't recall the specifics but for most welding tasks fluxcore is just as good as MIG especially with talking about repairs.
#3 you will need to to excellent prep and bevel the edges of that crack or plan on welding from both sides (or both) to get a good repair with your little welder. Possible to do with multiple passes but a challenge for a novice.
/ Questions about a tank for my new Mig Welder... #22
Mainly for the big repair of the bush hog...but if you don't think I would get enough extra penetration with shielding gas then I won't even bother with it ...like Doc is suggesting...I mean for the welding I will do it is fixing rakes and rough stuff...I don't foresee being an artist and creating sculpture...LOL...Let me know what you all think...if I don't need the gas...I'd just as soon skip it...?????
In my opinion for what you are doing now, I would skip it. If you want to make prettier welds on thinner materiel's, indoors.. yes then look into it.
OK....I'll hold off on the gas and do all the prep work and give it a shot...Just so you know...I may not be a novice since I welded my son's rake....I had not even ever practiced...I had never welded ...I had just bought the welder and he was waiting with his rake ...it was a Sat and he came over thinking I already had it...as I pulled in...so I plugged it in and did burned some metal...( notice the welding speak ) and he was happy...I did not tell him that was my first weld...I stood up straight with pride and said....Any time son...LOL This has to be a pretty good welder ...the box stores , Northern Tool and Tractor supply get $350+ for them...it is not a HF special....
/ Questions about a tank for my new Mig Welder... #25
Don't forget to drill holes at each end of those cracks before you do anything!
OK - Thanks Shield Arc..I will do that , then do I do a spot weld at each hole I drill first or just run the bead to it ? I'll take before pics and post them before I actually do the welding...
/ Questions about a tank for my new Mig Welder... #27
What I like to do, drill a hole at each end of the crack, take the plasma or carbon arc torch, (sure you don't have either one:() scarf out the crack. A grinder will work, but has a tendency to cover up the crack where a carbon arc of plasma will open up the crack. Grind a V in the crack, if you can get to the backside all the better, do the same thing on the backside. I generally start my weld on the side of the hole that was drilled, and weld to the center of the crack. Feather down the stop / crater of the weld. Start the next weld on the other hole, weld to the crater / stop of the first weld. Clean everything up and weld until the crack is full. If you can get to the back side, grind down to the weld on the first side, and weld it up. It is best if you can work from both sides, make the root / first weld on one side, then do the other side, switch back and forth, until completed.;)
/ Questions about a tank for my new Mig Welder... #28
Bob, one more question. Are you sure your mower deck is 3/8"? That is really very heavy duty.
/ Questions about a tank for my new Mig Welder... #29
I wondered about that, maybe he meant 3/16. Even that is thicker than some
/ Questions about a tank for my new Mig Welder... #30
Exactly. 10 gauge is probably about or more than what most standard duty mower decks are made of. I don't think even the heavy duty mowers have more than 3/16 or 1/4".
But that is very good news for Bob as anything under 1/4" would be right in the sweet spot for a 110v MIG machine running fluxcore. No need to bevel and the repair could easily be done with one good pass or better one from each side along with the holes as Shield Arc noted.
Bob, Miller sells a very nice thickness gauge for cheap money. Pick one up, you'll need to know the actual thickness to get an accurate initial setting on the welder.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2019 Merlo TF42.7 (A60462)
2019 Merlo TF42.7...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
