Hydraulic controlled bucket QA?
/ Hydraulic controlled bucket QA? #1
CDN Farm Boy
Ottawa Ontario
Kubota B3300SU
I'm looking for ideas to convert my Kubota pin-type QA bucket to hydraulic controlled.
I change back and forth between bucket and forks a lot and am looking for ideas to make my life easier and my need to switch between attachments will only grow over the years. I've talked to Jery at Tach-N-Go + INNOVATIVE ATTACHMENTS about one of his but I'm looking for other thougths & options.
I've seen a couple different posts on converting a SSQA to hydraulic and if I had that style, it would be done by now. But I don't and am not interested in converting at this time.
The floor is open for ideas..........
/ Hydraulic controlled bucket QA? #2
Don't have much of a drawing pgm on this 'puter, but I'll try to explain one of my "brain farts" -
Make new lower pins for the tractor half (I'm assuming you're talking about the QA where uppers are "U" shaped, you drive up, lift and the attachment is picked up by upper pins in the "U") -
Make the new lower pins long enough for a pointy end (self-centering) that will stick out enough to get full diameter in both holes in the lower bushings.
These pins would ride in a long enough "carrier" to be trapped when they are retracted.
Small "floating" cylinder between the two lower (new) pins, supported in a "cage" that will allow a bit of side-to-side movement; if you use a normal cylinder, the body would need to move to one side far enough to insert/retract the pin that's attached to the body of the cylinder.
Cylinder stroke should be just enough to fully engage both pins, and retract them far enough so you don't damage the "pointy ends" of the pins. I would use the smallest diameter cylinder that has a rod nearly as big as your pins. Otherwise a stubborn fit may bend the cyl. rod when extending.
You would need a little flex in hose arrangement since the cylinder BODY would move about 4-5 inches from full engagement to full retraction, and stroke would need to be 8-10 inches - varies with the size of your gear.
For this to work, each pin should have some sort of "shoulder" and a stop, so that when one pin retracts far enough to release, it forces the other pin to retract, instead of pulling the "easier" pin too far.
Like I said, no drawings (yet), for now this is just another of the dozen or so "brain farts" that constantly roll around in my head til they "come to the top of the pile"... Steve
Your idea is quite clear to me, infact, I've had the same one. Yes, that's the style of QA I'm talking about.
The design of your idea quite simple and would be easy to execute but the problem lies with trying to find a cyl to fit within the available space and having enough travel. I need a minimum travel per pin of 5" (6" would be nicer) and have a maximum extended length of 24". Finding a 12" travel cyl with an extended length of 24" isn't going to happen unless there are magical cylinders that I'm not aware of. Even a 10" travel measuring 14" closed / 24" extended seems tough to find
/ Hydraulic controlled bucket QA? #4
Maybe a shorter stroke cylinder, some knuckle joints, and a bellcrank? (Think ancient, control-line model airplane parts, sized up)
since you shouldn't need anywhere near the force even a small cylinder can give, using the advantage of a short arm on cylinder and longer TWO arms connected to the pins, would give you the travel you need, if necessary mount the cylinder at right angles to pin travel...
Downside of that approach might be side loading in whatever you use for pin slide mechanism... Steve
/ Hydraulic controlled bucket QA? #5
I've thought about this many times also, but instead of hydraulic using a 12V linear actuator so as to not tie up my aux hydraulics.
I don't have pics, but if you look at how the handles work there is a pivot that you could attach directly to. The pivot is closer to the center of the tractor when "open" and further away when "closed". Just mount a cylinder with the proper stroke between the 2 and you would be golden.
ac
/ Hydraulic controlled bucket QA? #6
ac
Some skid steers use these 12v linear actuators.
/ Hydraulic controlled bucket QA? #8
As said, talking about the pin style not SS.
Steve, you are right about the linear actuators being slow. I never thought about using them so I just did a quick search. 0.2" per second on some...at no load. Yikes! That would make for a full min to move a 12" stroke. 0.07" per second at full load -- no way is that going to work. And the fully retracted length is much longer than on a hyd cyl. Ballpark of 1.5 times the stroke length at full compression.
/ Hydraulic controlled bucket QA? #10
I'm not done flogging this horse yet, but neither am I very close to doing it to my 580B (still working on remotes front/rear, articulation for a Samurai cutter, pin-on QD for front bucket, repairs, ad nauseum) -
But any time I can steal while having coffee, eating, etc, I try to put to good use - and since this particular mod will help both of us (and probably lots of lurkers :=) it would help if I had an idea of your welding/machining capabilities, either owned or accessible - some of my "brain farts" aren't as simple as others... Steve
/ Hydraulic controlled bucket QA? #11
This is would work. Port A, extend. Connect port B and C with a tee to retract. The cylinder would be solidly mounted in the center. The rods could be the pins.
Pictures from Google Image Search
But don't know where you could find one the right size, probably could have one made by a good hydraulic shop.
/ Hydraulic controlled bucket QA? #12
After using a bobact with xchange I really want this form my b26 backhoe buckets and front bucket. I am thinking about just buying the bobcat parts and making them work???
I'm better than most with a welder and have a buddy with a 2x2 CNC plasma table. He also has a lathe. Trying to keep as simple as possible for obvious reasons.
This would be ideal if I could get one the right size. You would have to have long enough rods that the engagement part never went past the seals though. It would be easy enough to build, in fact, I already have a "build it yourself" cyl waiting for a good use. I'd just have to get a matching one.
/ Hydraulic controlled bucket QA? #15
You said you only have 24" max - so 6" pins x 2, + 6" stroke X 2, + whatever thickness of pistons x 2 - math seems to be winning again :=(
Or were you being conservative on available space? Are your two bucket mounts really only 24" apart inside? Not familiar with Kubotas/models/sizing. My 580B should have plenty of room for a couple of the ideas we've been tossing around, but I realize it's a bit bigger than the average TBN'er rig :=)
I do like the twin piston cylinder tho, it'd simplify the rest of the build... Steve
Tight measurement is actually 25 1/4" between the pin bosses (now that I double checked). I want to leave a bit of room between the ear and the end of the pin when fully retracted but I could probably go up to 24 1/2", possibly even 24 3/4". There's less than 1/8" of slop between the bucket ears and the corresponding part of the QA so allowing for 1/4" clearance would probably be adequate.
I could also comfortably get away with 5 1/2" pins, including a bit of taper on the end. With a full-size mock-up, I may be able to get this down to 5 1/4"
5 1/2 pin x 2 = 11
5 3/4" travel x 2 = 11.5 (allows for the 1/4" clearance)
For a total of 22.5 leaving 2 or 2 1/4" for two pistons
A bit closer to beating the math but still not beaten.
I'll have to dig out my cyl to see how thick the piston is but I still have my doubts that I'll be able to get 2 of them with nuts into the 2" space :-(
Yes the twin piston idea certainly makes things easier if it would fit.
Thanks for those links.
I'm quite familiar with the steering cylinders from full hydraulic steering on off-road buggies and was my first though....."If I could just get one of those that both ends went out but I've never seen/heard of them" In fact, I went this week to one of the biggest hydraulic shops in my area (over 1M population) and they have never heard of them (the double piston) -- ever. A quick phone call to their custom cyl builder and got a MINIMUM quote of at least a grand, more like $1500 or better to build what I'm asking -- if it could even fit within my space requirements. That's not going to fly. But I do know I could easily build it for under $500 with 2 of the Build-it-yourself kits, including some $$ to my buddy with the lathe.
Xman, That's a very helpful link. Looking at the different parts on it pointed out that there was a missing component from the original math -- while the piston thickness was accounted for, missing was thickness of the head area. This is significant as I'd want the engagement part to stop before it went thru the head seals, which by my reading of the measurements on this page will add approx 4" to the design which I certainly don't have room for.
I did a mock-up out of some electrical conduit I had kicking around and I can get by with 5" pins extending from 24 3/4" max allowable width at full retraction. So to try the math again:
5" pin + 2" head thickness + 5" stroke + 1" piston & nut X 2 is still more than the 24 3/4" I have available. Dang math wins again. Argh.
This would be a nice option on the next larger frame tractor but just ain't going to work for me.
On the next option......
/ Hydraulic controlled bucket QA? #20
OK, the crappy weather made me even lazier than usual - :thumbdown:
Here's one thought that's been worming its way thru my "little grey cells", as Inspector Poirot would say -
You might need the thick bushings shown in order to keep the full diameter of the pins trapped/guided, I would set this up so the pins can't ever escape the bushings unless you dismount the cylinders.
The "dogleg" for pin offset would need to be at least 1/2" x 1-1/2" flat bar, and the offset from centerline would need to be as little as possible and still get each cylinder to bypass the other one. Otherwise there would be too much side stress. If there's room, one of the two attachments to the "dogleg" should be a clevis - although the flex this would introduce might require too thick of a pin bushing for everything to fit :confused:
If you cut off anything on the cylinders that sticks out and isn't necessary, I think this would get you under your total width limit. It would also test your statement about welding skills :D (not that I doubt you)
It might be necessary to only mount each cylinder at its rear, letting the long bushing keep the other end aligned.
Best I got so far... Steve
