My AUX Lights Project
/ My AUX Lights Project #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
Well, I finally got around to doing an AUX Lights project on my Grand L 3540. I had actually started this project 2 years ago and after spending some time on fabricating and painting the ROPs brackets, I wasn't pleased with how they looked so I abandoned the project.
Fast forward and lots more research on TBN, I finally found a design / setup that I liked and I thought would be within my reach, given my limited tools and experience. Many thanks to TBN member "Boutym" for posting his pics / setup, which I stole shamelessly for my project.
I installed 4 x 27W LED flood lights on the ROPs - 2 each facing forward and backward. Here is the kit of parts that I used for this,project. The square trailer bolts are stainless steel.
When I took the cowling off to install the switches, I noticed two rust strips on the inside. I cleaned them up and ended up repainting the whole thing after I cut the holes for the switches.
The brackets are simple 2" angle iron that I cut using my sawzall with a metal blade and then cleaned them up on my grinding wheel. Drilled some holes and then painted them up to match the ROPs.
As far as wiring goes, I ended up using 2 of the 3 AUX connectors that came with the tractor. This made the wiring super easy and contained everything to the back of the tractor. These AUX connectors are already wired to the ignition, so that should keep me from running down the battery if I accidentally leave them on. They are on a 10amp circuit which is more than enough for these LEDs.
I'm very pleased with how they turned out and although I don't use my tractor that much at night, I will be very happy to have these available this winter when plowing snow. Maybe I'll do more work at night now that I have these!
Again, my hats off to Boutym for inspiring me to pick up this project again.:thumbsup:
/ My AUX Lights Project #2
That came out really nice, I bet it helps having the light up on the rop.
Bruce, thanks for your kind words. I just came in from trying them out in the dark and WOW! Nothing compared to the factory headlights. I'm really happy with the light output of these LEDs.
That's a really clever place to put the light switches. I like it!
Joshua, thanks for commenting on the placement of the switches. At first I was thinking of putting them on the dash, but then when I decided to use the wiring that Kubota provides for accessories just behind and to the right of the operators seat it was almost a no brainer to place them where I did. Also, I'm really happy I discovered those rust areas under the cowling and was able to repaint it. Almost as if those areas were missed during the factory paint process or something blocked the sprayer from hitting those two areas.
Since I may want to add some other switches in the future, I left room for logical placement of two more where they wouldn't look crowded. I'm going to place my order for the two additional switches next week just so I have them "in stock" and then I'll know they match.
/ My AUX Lights Project #6
swear i have seen those lights somewhere before
/ My AUX Lights Project #7
Looks good for sure. I'm guessing you don't fold your ROPS often ?
I did a similar mounting on mine but kept them up as high as I could on the lower part of the ROPS so I could still fold it when needed.
/ My AUX Lights Project #8
That is a nice, simple, and inexpensive mount. Thanks for posting.
Please fill us in on where you sourced the lights and how they work.
Dan,
Hope you enjoy your set as much as I do. They seem really well built and rugged enough for a tractor application. How long have you had yours? Still happy,with them?
Hey Farmboy, thanks for commenting. No, I haven't had my ROPs down since I bought the tractor and I don't think I will in the foreseeable future. If I do ever have the need, they're easy enough to disassemble. How about posting a pic of your AUX light setup?
Milkman,
Thanks for your kind words. It took me awhile to find the mount I would be happy with and one of my criteria was keeping it simple! The LEDs were sourced from eBay LEDStores. Great people to work with and they had them delivered really fast! I tested the lights the other night and I couldn't believe the difference they make. I'll definitely be able to work a lot safer at night now that I have these installed!
/ My AUX Lights Project #12
Dan,
got mine off of amazon, 4 for 100 bucks. they are GREAT!!!!! i think they have been on for about 6 months or so. i started out having trouble with the switch i bought from the auto parts house, after i complelty switched styles i have had no issues. i have not had any issues with the battery which is what i was a little worried about since i did not get the upgraded alternator, dynamo, flux capicitor, or what ever bota calls it. love em!!
/ My AUX Lights Project #13
Just el-cheapo standard tractor lights I had kicking around, I'd rather LEDs but why not use these that I already had. I installed first, then when I did my rear remote installation, I tied the two mounts together. Looking at it tonight, if I move the rear light in and back just enough to drill a new hole, I could raise them and the valve another 2". Since they are about ear height on me, I had to make a shield to keep from blinding myself when I turn around or reflecting off my glasses. Shield is a piece of old aluminum shovel from the junk pile held on with a hose clamp. I intend on a matching pair for the other ROPS post, just haven't gotten there yet.
Grote switches mounted in the removable panel, room for one more if I want.
Farm Boy,
Thanks for posting those pics of your setup. Always good to see how fellow TBNers tackle different challenges. I like how you combined the two mounts - seems to work very well. I know what you mean about needing a shield now that I've tried mine out at night, I may be making a few adjustments as the LED floods cast a pretty wide beam that catches my peripheral vision and boy are they ever bright!
/ My AUX Lights Project #15
Looks good!
Where did you get the SS u-bolts and the switches?
Thanks!
Looks good!
Thanks!
FTG-05,
Thanks for your questions.
The stainless steel square U-bolts came from Pacific Trailers - they specialize in marine trailer parts. The fit is perfect for the ROPs on the L-series.
The switches came from eBay seller Komsa out of Texas. Fast delivery and even helped when I had wiring questions to get the LED lights to show when switched on.
Hope this information was helpful!
/ My AUX Lights Project #17
/ My AUX Lights Project #18
Well dang you guys seem satisfied with these lights. Do they cast the whiter light rather then standard halogen yellow? It always seems to me that the whiter light makes it easier to see a lot of things like pot holes, ridges, dips and anything else that's contour related. I may have to get me a few of these because I just have standard cheapy halogens on mine right now..
Jason,
The basic answer to your question is "yes", the light is much brighter and whiter than the halogen work light that I purchased from Kubota when I bought the tractor new. I'm super satisfied with these new lights and with winter coming up soon, I'm sure I'll get some good use from them while out plowing in the early mornings (before work) and evenings (after work). Some day I'll trade in my open station tractor for a cabbed version, that way I won't have to dress up like an Eskimo whenever I want to go outside to plow. To be honest, the only thing that has stopped me from taking that step up till now is that I couldn't fit it in my garage (door is barely tall enough to clear the ROPS) and I refuse to store a tractor outside. Some day I'll get around to building my dream barn, but until then, it just means an extra few minutes to put on all the gear.
Take care,
Thomas
/ My AUX Lights Project #20
they are the difference between night and day!!!!!! lol the field of view is huge, i actully thought about using them on my ZD326 mower to mow at night, they are that awsome!!!
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
1999 Johnson 25hp Boat Motor 225hp 2-stroke Boat Moter (A66738)
1999 Johnson 25hp...
2005 INTERNATIONAL 9400I (A67714)
2005 INTERNATIONAL...
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2022 CATERPILLAR 349 EXCAVATOR (A65053)
2022 CATERPILLAR...
