In expensive UTV plowing lights
/ In expensive UTV plowing lights #1
DIXIEDOG
Maine
International 2544 / Gator 825i/L2501/General
I recently installed a Boss V-plow on my Gator 825i to get it ready for plowing season, I noticed due to the very high plow height my stock headlights will need a bit of help for when I'm plowing this winter. What are some decent work lights that won't break the bank that would work well for plowing when mounted up on the roof?
/ In expensive UTV plowing lights #2
The Boss light kit isn't too expensive, I was quoted under $200.
Have you seen the Boss light kit? I've heard mention of it but haven't seen it yet, I thought about that as a solution as well. The only other concern I have is I believe they mount in the push frame on front of the Gator which would put them in a pretty vulnerable location for when I'm out four wheeling. I'll have to do some more research and see if I can find a set installed to look at. Thanks for the suggestion.
/ In expensive UTV plowing lights #4
I'm about to place my order with the light kit, I'll post pics when I have it set up.
Matt
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
Kubota M125X (A60462)
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
