Problem
/ Problem #1
sampen
yukon, ok
terramite 3-15
Okay need a little help on a problem I have! When I raise the boom on the backhoe the front bucket tips back! Anyone have any Idea what is causing this. Nothing has been changed on the terramite other than new cylinders. Just started doing it a few days ago!
Thxs Sam
/ Problem #2
Most likely the control valve is leaking past internally.
/ Problem #4
Yes as Pontiac58 said check the loader control valve could be as simple as a worn linkage that is opening the curl and lift valve together. Also be sure you are not putting side pressure on the handle as it shifts between lift and curl easily. Also you could need to rebuild the valve once they develop bleed thru. it usually keeps getting worse.
/ Problem #5
Run heavy equipment for a living and once come across a dozer that the controls were not working properly on. Water had gotten into the hydraulic oil and froze busting the control block internals.
Really hope this is not your problem. Just thought I would throw the idea out there
Good luck
TIRE RACK WITH TIRES (A68842)
TIRE RACK WITH...
2015 INTERNATIONAL LONESTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 INTERNATIONAL...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
CAT D9G Rollers (6) (A68134)
CAT D9G Rollers...
Asphalt Roller Tire (A68134)
Asphalt Roller...
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
