Problem
/ Problem #1
sampen
Bronze Member
yukon, ok
terramite 3-15
Okay need a little help on a problem I have! When I raise the boom on the backhoe the front bucket tips back! Anyone have any Idea what is causing this. Nothing has been changed on the terramite other than new cylinders. Just started doing it a few days ago!
Thxs Sam
/ Problem #2
Most likely the control valve is leaking past internally.
/ Problem #4
Yes as Pontiac58 said check the loader control valve could be as simple as a worn linkage that is opening the curl and lift valve together. Also be sure you are not putting side pressure on the handle as it shifts between lift and curl easily. Also you could need to rebuild the valve once they develop bleed thru. it usually keeps getting worse.
/ Problem #5
Run heavy equipment for a living and once come across a dozer that the controls were not working properly on. Water had gotten into the hydraulic oil and froze busting the control block internals.
Really hope this is not your problem. Just thought I would throw the idea out there
Good luck
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
2015 Ford F-750 Party Shuttle Bus (A66736)
2015 Ford F-750...
MANIFOLD (A68842)
MANIFOLD (A68842)
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
