Bush Hog Blades
   / Bush Hog Blades #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
Several weeks ago I replaced 4 blades on our 10' Howse Rotary Cutter...
The old bolts that attached the blades to the stump jumper utilized a lock washer to tighten the bolts...
I went ahead and purchased 4 new bolts with the blades and low and behold, the new bolts have castle nuts with carter pins for securing the blades...
I do have a problem though...
As tight as I can get the bolts, only 1/2 of a hole is showing through the bolt for the carter pin...
My only solution that I can see is to take the stump jumper off and grind down the stump jumper attachment bars...
That would give me enough tolerance to put in the carter pins...
I am thinking that my easiest option would be to utilize lock washers on the new bolts and call it a day...
Any input and thoughts would be appreciated...
   / Bush Hog Blades #2
Yeah.. If you never had a problem before just using lock washers I say just get some washers and crank them down tight.. I also use loctite but that's just the way I do it.
   / Bush Hog Blades #3
It would be easier to either shave a bit off the nut, or take a little air cut-off tool and cut down a bit of the castle's that's blocking the hole.
Few other suggestions...how tight is "as tight as I can get"??? And was that dry?? if so, add a little never seize or oil and try again. May get just enough.
Also, perhaps try re-arranging nuts and bolts around. Different combinations may be machined slightly different.
   / Bush Hog Blades #4
Find a nail that will almost fit thru the available open hole. Tap it thru.
   / Bush Hog Blades
Thanks for the help guys...
I am torquing those puppies down with a 3/4" drive air impact wrench rated @ 950 ft.lb...
After that I am putting a 20" long 3/4" drive breaker bar with a 36" pipe attached for leverage...
The bolts are tight as can be after the air impact and If I was to put any additional pressure on the breaker bar I could easily demolish it...
I pull down on it until I feel the breaker bar start to give...
I believe that my impact is delivering very close to 950# of torque...
   / Bush Hog Blades #6
It is possible you are over torquing them.
The bolts on my bushhog 306 (which takes a 1-11/16" socket) only have a torque spec of 450 ft-lbs.
I am guessing 950 is a tad much.
IF you have a way to measure (or guesstimate closely), use your breaker bar and cheater pipe and only apply about 100-120# of force at a distance of 48" from the center of the socket head. That should get you over 400#. and with a castle nut, that should be more than enough.
   / Bush Hog Blades #7
Are you using the lock washer still?
Dumb question maybe, but I had to ask.
...Also, they are cotter pins. Not that it matters though.
   / Bush Hog Blades #8
Pardon my shock/ignorance, but WTF did you come up with that procedure?
You have a driver that provides a (somewhat) known torque, and then you go to a breaker bar and wait for it to "start to give" - what exactly does that feel like, anyway?
I'd check your torque specs in the manual (or a standard chart for your hardware size) and roll with that. 950 seems way high for an application like that. $0.02
   / Bush Hog Blades #9
I think he was just trying to demonstrate that he could not get them any tighter and it still wasn't tight enough to expose the hole. I think air tool ratings are pretty optimistic anyway, especially since they are usually reverse biased and apply way less torque in forward.
I would have to check, but aren't the blade bolts spec'd a lot lower than the center stump jumper bolt? I think that 450 figure is for the center bolt.
   / Bush Hog Blades #10
Why don't you just cut the slots a little deeper on the castle nuts so the hole in the bolt will be exposed?
2025 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A49462)
2025 LandHonor...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
19009 (A48082)
19009 (A48082)
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
John Deere A Tractor (A50514)
John Deere A...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52128)
John Deere 5090E...
