Removing PTO shaft from Caroni?
/ Removing PTO shaft from Caroni? #1
ejeffas
Kentucky
Kubota B7500
Total rookie tractor owner here. Just bought the tractor and a 5' Caroni finish mower. While testing it out in the field, the PTO shaft sheared. I can not figure out how to remove it from the mower gear box. Anyone have ideas?
/ Removing PTO shaft from Caroni? #2
Are you sure it did not just break a shear pin?
The shaft is actually split with a crack running about an inch up the shaft was well.
/ Removing PTO shaft from Caroni? #4
A lot of these gear boxes have a splined input shaft but not familiar with the Caroni. Still should have shear pin someplace so expensive PTO shaft is not the weakest link if you hit something.
/ Removing PTO shaft from Caroni? #5
If it has a "shear bolt" usually a grade#2 1/2 inch bolt.. Then they usually have a "circlip" on the front edge of the smooth PTO shaft going into the mower.. This is to prevent your PTO shaft from flopping around and flying off when the "shear bolt" well.. shears.. I looked on the Caroni site, and see that there are 3 different input shafts. 2 splined and one smooth. Which one do you have?
I am assuming that is mine. It has a plate on it that says "Type 590". Everything else got painted over by the prior owner.
So, let me correct what the issue is. The tractor side of the PTO shaft cracked and split allowing the two pieces to separate. PTO shaft.jpg
I have removed the bolt that is under the plastic cover near the gear box, but still can't get the mower side to let loose.
/ Removing PTO shaft from Caroni? #9
So, let me correct what the issue is. The tractor side of the PTO shaft cracked and split allowing the two pieces to separate.View attachment 337479
If if is the smooth shaft, did you check for a clip? and if it is splined it should work just like the other end to release the U joint. Either a button or the slide collar or the twist collar.. There are just 3 ways to remove the U joint that I know of. I bet your PTO shaft did not have enought overlap to begin with, (not long enough) ..that is why it split. I am thinking.
James K0UA
I can't feel a pin or button. I will spray the whole thing with PB Blaster to see if I can get something to rotate or slide. Thanks a bunch for the info. I was almost afraid I was going to have to go into the gear box itself with the way my luck goes :laughing:
/ Removing PTO shaft from Caroni? #11
Well. is it splined or smooth?
/ Removing PTO shaft from Caroni? #12
A couple of good pictures would be worth ..uh... well a lot!
Here are pics of the cleaned up mower joint. Have a feeling it is those C shaped springs I don't have the tool to remove. There are two of them, one on each side.PTO joint.jpgPTO clip.jpg
/ Removing PTO shaft from Caroni? #14
No.. it is not the "C" shaped clips on the ends of the yokes. Look at the end of the shaft that comes out of the mower. The rusty brown shaft.. Look at the very end for a wire type clip in a groove. pry it out, I can't quite see it. I need a better photo to be sure, but it is not the C clips, that is how you take apart the yoke, and you need a vise and sockets or a press and special pliers like you said, But this is NOT what you want to do. Also the yoke may be rusted onto the shaft. I believe your shaft is a smooth shaft, and I cant tell if there is a roll pin or what going thru the shaft. Normally it is a shear bolt, but I didn't see one.. Is there a hole in the black outer shroud to line up to put a drift punch (roll pin punch) thru the hole.? The idea is to get the yoke off of the mowers shaft so you can get a complete new shaft right?
I removed the shear bolt. The hole in the black shroud lined up with the bolt I removed.
The purpose is to get this off so I can replace it with a new PTO shaft assembly. Guess I need to give it a few whacks with the trusty ol' hammer to try and break things loose.
/ Removing PTO shaft from Caroni? #16
Before you whack, look carefully for that wire clip on the very end of the rusty brown shaft. look for a "break" in the wire and flip it out with a screwdriver or something. I have never seen one without one.. or at least look for the groove. maybe the clip has let go or maybe there isnt one. Your there and I am not.
Will do. Thanks so much for giving me some sort of direction
/ Removing PTO shaft from Caroni? #18
Please report back what your results were if you are successful or even if you were not.. It helps us help others.
James K0UA
/ Removing PTO shaft from Caroni? #19
Please don't forget that when you get your new shaft, you will likely have to "size" it for your tractor. I believe the reason your original shaft faild was do to insufficient overlap of the two halves of the shaft. But if you leave the shaft too long your PTO stub on the tractor and its seals and bearing can be damaged. As you lift and lower the shaft, the shaft extends and contracts at some point in that arc your shaft will be as fully collapsed as it is going to be. You still want some room in the "telescoping" of the two shaft halves so as to not "hit"the stop and cause it to be jammed into your PTO stub. Conversely you don't want it to be too far extended. or the overlap will not be enough to be mechanically sound. it can cause the shaft materiel to "split" as there is too much torque on too small of an area. Good luck
James K0UA
Went out and removed the bolts holding the black cowling on so I could get to the back of the yoke. See no clip in the grove on the front of the rusty old shaft so I hosed everything down again with PB Blaster. Hopefully by morning it will be more cooperative. One thing is for sure, the seal at the grease fitting was shot. In fact, I expect all of them are. At least the tractor is in really good shape.
Once I get the dang thing off, I will be better able to know what to order. I sure won't be getting it from Tractor Supply. Yowza! :greedy:
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2007 Peterbilt 379 T/A Kill Truck (A64194)
2007 Peterbilt 379...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 PETERBILT 579...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
