Chainsaw Ignoramus
/ Chainsaw Ignoramus #1
Sparks45
Maryland
n/a
That's me. I have some questions and am wearing my kevlar suit so don't spare my feelings :D
I recently bought a Stihl Kombi and added the pole saw. I've used it twice, for a total of maybe 15 minutes and am trying to carefully follow the instruction manual. Tightened up the chain (when cold) between uses. Manual said it would need it - and it did.
We're looking to build a new home on 5 acres we bought last fall - ~2.5 acres are wooded and haven't been touched in probably 30 years. Besides the pole saw I'm going to pick up a chainsaw once we move in. Given the quality of the Kombi, I'll be picking up a Stihl.
In preparation - and for maintaining the pole saw - I bought a Harbor Freight chain sharpener on sale for $29.99 - it MUST be worth that much... Someone posted some very good, easily understood instructions on how to tune it up. I tried to find the thread to thank the poster but couldn't find it. I followed them and still had trouble with the pressure plate grabbing the chain too high, causing it to lift and tilt. After adding the washers to the small screw below the pressure plate knob it still did it. I wound up taking a Dremel with a grinding wheel to the top of the pressure plate and now it clamps the chain sprocket teeth firmly and the chain doesn't move at all.
I also have an old chainsaw that was given to me 20+ years ago. The story behind it is that the guy who gave it to me had been given it by a coworker of his but my friend was too scared of it to use it. His story was that the guy who gave it to him got it from his dad. His dad had a contract with the US Coast Guard to clear brush on a base somewhere (New England, IIRC) and the USCG gave him a new saw every couple of years. I did a little searching on the net and it's an Italian made saw...it's in the shed, it's dark and not worth going out with a flashlight to look at it. I'm guessing the saw is ~25 years old. I used it to take down a wild cherry tree right after I got it and put it away. Obviously, it won't start now and I don't know if it's worth the work (if I can do it) or expense (if I have to pay someone) to get it running.
The saw came with a nice blow-molded case, a couple of hand tools, chainsaw file, a nice pencil-tip grease gun and 3 used chains. One of the chains was obviously never used after sharpening and the other two are in need of sharpening before use - if they were to be used again. Once I got the sharpener tuned up, I put one of the chains in to try the sharpener.
The chain was all gunked up but with not much, if any, pitch/sap on it. I sprayed it down really well with WD-40, wiped it down with a couple of those blue paper shop towels and blew it 'dry' with compressed air. On closer inspection I'm not sure the chain is in very good shape. Some of the rakers are bent sideways a bit and a couple appear to have been filed down. I figure it's a good candidate for fine tuning the sharpener and practicing.
Would the old chainsaw be worth time/money to get it running? Do you clean your chain before sharpening? If so, how clean?
TIA,
Charlie
/ Chainsaw Ignoramus #2
i wouldn't mess with the old saw they can be a pain to start but that's my opinion.i do not clean the chain before sharpening.
/ Chainsaw Ignoramus #3
I hand sharpen my chains. I read posts about people grinding away at teeth ruining temper or consuming way to much tooth. Stihl and Oregon have articles on chains and sharpening that you should read up on.
If the chainsaw does not have a safety brake you might not want to use it. Do some Google research on chainsaw kickback and ways to hang on to the handle so the brake can be useful.
It takes about $15 in parts to get most 2 cycle machines running again. New fuel lines and a carb repair kit. Sometimes an impulse line depending on design. Add $50-100 in labor for a shop to look at it.
Thanks guys. pretty much what I expected on the old saw. No chain brake & no hand guard. I can't think of a use for the power head..oh, maybe for a little go-kart for my grandsons in a couple years.
Thanks for the pointer to Stihl & Oregon. I'll read up on them.
Charlie
/ Chainsaw Ignoramus #5
If you post the make and model of the chainsaw, it's likely we can tell you something about it. Also, we loooove pictures. :)
/ Chainsaw Ignoramus #6
Long ago, I used to sharpen my chains. Since we moved here in 2000, I've always just taken the chain to a local hardware store that uses a machine shop to sharpen them for $6. No more crooked cuts and time spent sharpening. I just kept a spare chain.
Had to give away my 1992 Stihl 009L and a Craftsman. Can't use them with a pacemaker. Had a couple B&D 18v ones that my wife and I use. They work great for what they'll do. We've 3 batteries to use on them. Need at least that many to do much. Stihl would always started good once warmed up. Definite technique for starting it cold. Never did like the Craftsman.
Ralph
Ralph
/ Chainsaw Ignoramus #8
i bought a harbor freight chain sharpener 2-3 years ago does a nice job,watch for when they are on sale.
Here it is. The pencil-tip grease gun is sitting on it in one of the pics.
Make is Olympic and it appears the model is 254. It says "Made in Italy" on it.
Charlie
Olympic chainsaw R side.jpgOlympic Chainsaw L side.jpgOlympic chainsaw & case.jpg
/ Chainsaw Ignoramus #10
Like Ralph. I pay $5.50ea. for my chains to be resharpened and it's a better deal than spending my time on them. I normally take them all in at once, 10" 14" 20". I have 4-5 chains per saw, so rotating the chains is no big deal.
/ Chainsaw Ignoramus #11
Thats what most of my firewood cutter guys do. 4-12 chains dropped off and I do them for $5 for 24" under.
Sometimes if I am not busy I will do them while they are here and we just BS and have a brew while hooking them up.
/ Chainsaw Ignoramus #12
That's real nice - here it's about $15 for the small chains. I never asked about the regular ones (26 to 34).
I run chains from 16" to 42", but mostly 28" plus. My saws are a 35cc Efco, Stihl 021, JD CS62, Stihl 660, Stihl 660, Stihl 088. I bought a Northern Tool grinder for about $80 years ago, I also use a Grandberg File n Joint. I mainly did some chain saw milling (CSM). My routine is to hand sharpen, or touch up 3 times, then use the Grandberg, repeat (hand 3 Grandberg 1) for 2 more "Grandbergs", then take them to the grinder. The hand sharepning and Grandberg are normally done on the saw. If for some reason a chain gets "rocked" it goes to the grinder.
The Grandberg helps confirm the angle and the grinder makes it even more accurate.
When sharpening also pay attention to the rakers.
/ Chainsaw Ignoramus #13
I've never used a battery powered chain saw, and I sold my last gas powered one when I moved back to town nearly 11 years ago. But about two and a half years ago, when a little wind and hail knocked down a tree in my yard, I went to Home Depot and bought a cheap ($50) Homelite corded electric chainsaw, and I was very pleasantly surprised that it worked much better than expected. And some time later, a friend had a tree blown down and I went over there and helped him cut it up with this cheap saw; worked great and still hasn't had the chain re-sharpened.
/ Chainsaw Ignoramus #14
Here is some info about that saw.
Model Profile: 254
As far as weather its worth it to fix....depends on what it needs. If it ran when put away, odds are the cylinder, piston, and ring are just fine. See if it turns over. Pull easy on the rope. If there is any resistance, put a little wd40 down the spark plug hole and let it sit.
But odds are it just needs a carb cleaning or carb kit. which is $7 with free shipping on ebay Carburetor Rebuild Kit for Tillotson RK 23HS for Tillotson HS Carburetors | eBay
And might need a few bucks of fuel line and a fuel filter. But if the motor turns over freely and has compression, I'd say its worth investing ~$20 to see if she will live again:thumbsup:
Thanks for all the info, LD1. I've printed out the info in your link. Interesting that it's 32-35 years old. Yep, it ran fine when put away and turns over easily now. I need to clear a couple of other projects off the bench so I can tear it down and see what it looks like. For the amount of use I expect to have for a chainsaw, it's definitely worth $20 to get it running again.
Charlie
/ Chainsaw Ignoramus #16
Keep us updated when you get around to tearing into it:thumbsup:
/ Chainsaw Ignoramus #17
I been looking at the 40volt battery powered saws too for awhile. For inside my barn use or when no power and IF I had no mix on hand. Doubtful, but you never know.
Oregon even sent me one of theirs to test out for FREE, shipping to me and back. I just cant see paying $400. If one was cost effective I might pull the trigger on one.
So still looking at the cheaper ones.
Chariot Scrub 20 Electric Floor Scrubber (A64194)
Chariot Scrub 20...
2019 CATERPILLAR 315FL CR EXCAVATOR (A65056)
2019 CATERPILLAR...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
