I realy appreciate the input!
The tractor does not have any adjustment to prevent the 3pt from rising, there is a downward control but the upward movement is no different regardless how this is adjusted.
As noted, this grass catcher on this new sweeper is 2 1/2 times the size of the prior sweeper, so there in not much I can do to shift the load forward to increase tongue weiight, in fact since this equipment is longer it probably takes less weight to cause the 3pt to rise than the old one.
It looks like stay bars or chains offer the same result or concern depending on how you look at it. Since I have two teen age sons who help with the yard work I'm a little concerned with installing either of these items. I may understand but it's only a split second lever movement that could cause damage.
So, it looks like I have only one option which is to replace/modify the length of the tongue on the sweeper so that I can bypass the draw bar and attach to the chassis where I currently have a 2" ball, probably an additional 18".
Should not be a major change, I probably have some thin wall tubing laying around somewhere.
